SOURCE: Sharp Remote Control Problem
trying removing the batteries and reinstalling then the reset the remote and then tell me if it works if you have lock the parental function on sould like
SOURCE: Can My Comcast TV Remote Connect To A Sharp TV
the codes for Sharp LCD's are 10093 and 11602...follow the normal programming instructions but use these codes....newer remote manuals may have these codes but however the one i had didn't...hope this helps
SOURCE: Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
SOURCE: I have a sharp lcd tv LC47SB57UT that I cannot not
i had same problem and found the code on a directv forum
it is 11089
SOURCE: sharp model ga667wjsa not working on one tv but
Try unplugging your tv. And then plug it back in and try remote.
