Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Thw pictures are coming out black
I turned my camera on and the screen is completely black, so i took a picture and the picture comes out dark as if someone is covering the lense
Posted by Kerina Moraris on
bradens_swee
    New Friend:
Should be a brighness setting you can adjust in the settings menu
Posted on May 01, 2012
  • 2 more comments
  • ron dijcks Jul 10, 2014
    3 things to try.
    1. remove the battery, and replace after a minute.
    Sorry, the "enter" button adds a comment instead of going to next-line.
    IF you can see the menu, try to change the screen brightness. I seems that you can see photographs so hopefully there is enough brightness for you to make this adjustment. As well, you could try resetting the entire camera. This function is also in the menu, settings.
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: Problem with my camera
Go here and search knowledge base for E18: http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=224&modelid=10599 Issue: Lens will not move and camera may display an E18 or "Lens" error. Solution: Possible solutions for an E18 or Lens Error message PowerShot SD300 The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: * Hold the camera so that your fingers do not touch the lens unit when you are shooting. * Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case. If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred.
Posted on Mar 07, 2007
advance
David Millier
  • 107 Answers
SOURCE: canon powershot SD 100 - I can't see anything but a black screen
This problem is caused by a stuck shutter assembly. Normally the shutter is open which allows light to enter the image sensor and show you the live preview you see on the screen. When you take a picture the shutter closes which allows the image sensor to record what was seen at the exact moment the shutter closed. The shutter is stuck closed, causing the image sensor to always be in the dark. These shutter assemblies are extremely small and delicate. The miniature parts can become jammed with just the slightest bit of oil or contaminant, or the slightest misalignment of components. The problem can sometimes be fixed by gentle tapping of the camera on a solid surface. If you are going to try this be VERY careful, and do not tap the camera on the buttons, lens, or battery door. If this does not solve your problem then the camera is going to have to be taken apart and the shutter cleaned and reset to allow free movement. This repair costs $125 to $145.
Posted on Jun 16, 2007
Anonymous
SOURCE: Black Screen/Viewfinder
Mine too! Thank you so much for posting this issue!!
Posted on Sep 07, 2007
Anonymous
  • 13 Answers
SOURCE: LCD screen black with white specs in picture and movie mode
With the power off, hold the camera in your palm and smack the front of the camera on your leg or arm. You might have to smack it a few time to get it to work. It has to do with the camera CDD lense (shuttle) being stuck. By smacking it around, it will free up the lense. Being extra gentle with it though. It worked for me. Hope this help.
Posted on Nov 11, 2007
darntoothysa
Thomas D.
  • 489 Answers
SOURCE: Black LCD screen/ not 'seeing' picture. Canon EOS 400D camera
Hi
The Digital Rebel XTi doesn't have 'live view' mode, you can't see what you're taking a picture of before you take the picture.
Thomas
Darntoothysam com - Digital camera parts and repair.
Posted on Nov 11, 2008
Panasonic Lumix DMC FX12
HI,
It's impossible to turn the camera off. Only way is take out the battery.
No button warks, but I can change the shooting mode and turn playback, but I can't change the image in playback mode.
Please, help me to solve this problem.
I think, the camera needs to be restarted, but how to do that?
Thanks a lot.
Jun 17, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
My pictures are black i cant see anything when i try to take a picture
Your pictures will usually come out black if you're taking those against the light. Check the lighting or your flash (esp. when it's dark - flash is needed). You should know if your camera is for indoor or outdoor use.
May 08, 2009 | Fuji FinePix Z10fd Digital Camera
Camera is dark
when i go to take a picture or a video it comes out dark. you can't hardly see the person i took the
picture too. It's very fustrating not knowing how to fix the matter. all those buttons are not helpng at all. Can i get any suggestions on how i can make the pictures come out brighter?
Nov 06, 2008 | DXG Technology DXG-305V Digital Camera
My digital camera screen has gone dark, but the camera still takes pictures. How do I fix the screen?
the same happened to me! and also it sometimes randomly turns off. but it takes pictures if it doesnt. mine is canon sd1000 powershot
Apr 16, 2008 | Cameras
Black screen
Piece of junk that took great pictures for 1 year and now shows a black screen. Do not buy any Canon products. We also have one of these pieces of junk at work, now displays a E 18 code. Appears Canon wants to make mucho dollars by producing ****.
Apr 13, 2008 | Canon PowerShot S2 IS Digital Camera
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
Repair of digital camera
If you see all black in the viewfinder something bad has happened to the lens. It could be stuck, tilted, etc.
It will need to be taken apart and serviced by a trained technician.
Nov 14, 2007 | Nikon Coolpix 5700 Digital Camera
Black LCD Screen
Faulty main or secondary board. Could also be faulty light sensor or iris. Not a user fixable problem unless you can get another f601 with a broken lens etc with good boards (to replace boards). Or a dead camera with good lens assembly (contains iris).
Very fiddly if you have the parts!!!!!!
Best advise is to sell it as faulty on ebay.
Aug 31, 2006 | Fuji FinePix F601 Zoom Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
117 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
