Question about Sharp EL-501WBBL Calculator
Where is the combination button on SHARP EL-501W calculator?
I am trying to do combinations on my calculator, but I can't find a button to do nCr problems.
Posted by amby316 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
There is no such key on this calculator. You can calculate it using factorials. To calculate nCr you can calculate n! / (r! * (n-r)!).
Posted on Apr 30, 2012
5 Related Answers
k24674
  • 8091 Answers
SOURCE: i want to calculate permutation and combination.
Use the sequence [2ndF][nPr] for permutations and [2ndF][nCr] for combinations.
Exemples: 10(nPr)3 is entered as 10[2ndF][nPr]3 [=] gives 720
5(nCr)2 is entered as 5 [2ndF][nCr] 2 [=] gives 10
Hope it helps.
Posted on Sep 17, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: need a manual for the sharp EL-5103S calculator
http://www.sharpusa.com/products/support/view_all_models/0,2326,32,00.html
I don't see that model listed...are you positive on exact model number?
Posted on Sep 05, 2009
informatica
Greg Cann
  • 1114 Answers
SOURCE: user's manual Sharp EL-531WH
You can download the manual from the link below: http://esupport.sharp.at/html/om/index.php?StartRec=50&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=30&SortOrder=DESC&OrderBy=Title&SearchString=
Posted on Aug 10, 2007
k24674
  • 8091 Answers
SOURCE: I have a SHARP EL-501W calculator and i am getting
The source of errors is most certainly due to the wrong schoice of angle unit (degree or radian). If the default angle unit set in your calculator is the degree, any value fed to the trigonometric functions (sin, cos, tan) is considered to be expressed in degrees. Consequently, if you calculate the arctangent ( tan^-1) of a value, the angle returend by that inverse trigonometric function is expressed implicitly in degrees.
Similarly if radian is the default angle unit in your calculator, any angle returned by an inverse trigonometric function (arcos, arcsin, arctan) is in radian.
Set the default angle unit as the one required by your problem at hand. This way, the angles returned will be in the right unit and you will not have a problem of interpretation.
Hope it helps.
Posted on Dec 07, 2009
k24674
  • 8091 Answers
SOURCE: PDF Manual Available for EL-501WBBL Calculator?
Here, I think I got you a link.
Posted on Jan 30, 2010
Where is the combination button on a ti 83 plus calculator
There isn't one. You can access the combination function by pressing the MATH key, selecting PRB, then selecting nCr.
Jun 28, 2014 | Texas Instruments TI-83 Plus Calculator
How can I calculate combinations with fx-991ES PLUS?
Use nCr (the shifted function of the divide key). For example, to find the number of combinations of five things taken three at a time, press 5 SHIFT nCr 3 = and see 10.
May 03, 2014 | Casio FX991ES Scientific Calculator
How do i solve this factorial equation? 8!/5!x3!
How to calculate 8!/(5!3!)?
For small numbers (8,5,3) you can use the factorial function key (I will tell you later how to access it) and enter 8! divided by 5!, divided by 3! For numbers greater than or equal to 70 you cannot calculate the factorial: the result is too large for the calculator's memory.
However the formula you wrote is an instance of a combination 8C5 or 8C3 (they have the same value.
Most scientific calculator have three functions: the n Factorial n!, the Combination function nCr and the permutation function nPr.
  1. Turn Calculator ON
  2. Select the Run icon and press EXE.
  3. In Run Screen Press the OPTN key
  4. Press F6> to pan to the other tabs
  5. Press F3:Prob
The first tab (F1) is marked x!.That is the factorial.
The tab (F2) is marked nPr is for the permutations
The tab (F3) is marked nCr and it corresponds to the combinations.
To use nPr or nCr you enter the larger number n, you press the F key under nPr or nCr. If you press F2 you see a fat P, if you press F3 you see a fat C. Complete by entering the value of r (the smaller number)
If your problem corresponds to Select 8 objects, 5 at a time regardless or order (combinations) you type 8 F3 5 and EXE Result is 56.
Aug 31, 2012 | Casio CFX 9850GA Plus Calculator
NCr button
That's because there is no such button. It's in a menu.
If you press the PRB key you'll see a menu which includes nCr as one of the choices.
Mar 25, 2012 | Texas Instruments TI-30 XIIS Calculator
I can't find the combinations (nCr) button on the fx 9750G11 calculator
In Run screen, enter the number whose factorial you want to calculate ( number can be at most equal to 69), press [OPTN][F6] to get to next page of menus.
For factorials
  • Press then [F3](PROB) then [F1] (x!) followed by [EXE].
For combinations
  • Press then [F3](PROB) then[F3][nCr][EXE]
For permutations
  • Press then [F3](PROB) then[F2][nPr][EXE]
Feb 06, 2011 | Casio FX9750GII Graphic Calculator
What is the nCr and nPr button for?
nCr is Combination. It calculates the number of ways you can choose r items out of n. For example, 52C5 is the number of possible five-card poker hands you can deal out of a deck of 52 cards.
nPr is Permutation. It calculates the number of ways you can choose r items out of n if the order of selection matters.
Dec 13, 2010 | Sharp ELW516 Scientific Calculator
How do i use the nCr button
To calculate the number of combinations of n items taken r at a time, enter n, press xy, enter r, then press 3rd [nCr] =. For example, to find the number of possible five-card poker hands, press
5 2 xy 5 3rd [nCr] =
Sep 09, 2010 | Texas Instruments TI-36X Scientific...
How to do nPr or nCr on TI-30x Solar (scientific calc.)
If you have an older version on the TI30x Solar (not TI30Xa or newer) then you must use a different key sequence for nPr/nCr.
52 [2nd][x/y] 5 [2nd][nCr] gives 2598960 (the x/y button is above the Pi symbol on my version).
8 [2nd][x/y] 3 [2nd][nPr] gives 336
This took me forever to find out, so hopefully it will help someone!
Jan 27, 2010 | Texas Instruments TI-84 Plus Silver...
NPr and nCr key
On calculators you calculate permutations and combinations as follows
Enter the number n then press key nPr, and the number r
18(nPr)5=1028160
For combinations, use nCr key instead of nPr.
18(nCr)5=8568.
Hope it helps
Apr 24, 2009 | Texas Instruments BA-II Plus Calculator
I want to calculate permutation and combination.
Hope it helps.
Apr 09, 2009 | Sharp EL-531VB Calculator
Sharp EL-501WBBL Calculator Logo
2,299 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
