Question about Smith Corona Typewriter - 350 DLE - Refurbished 350DLE with New Machine Warrant
Handle for a Smith C orona 350 DLE to turn paper holder bar
I used to know the part names, but forget everything. Need plastic handle on the right side of typewriter that turns the rubber roller that feeds the paper into position.
Posted by contact4020 on
Dick O Reilly
  • Smith Corona Master
  • 3,594 Answers
It is called a platen knob. Google smith corona dunkirk Ny they will be able to help you.
DickyO
Posted on May 01, 2012
2 Related Answers
Anonymous
  • 183 Answers
SOURCE: Smith Corona 240 DLE
pull the paper release lever and look under the platen as well as you can, to see if there are any forien objects. check if the feed rollers are all in place. the slots in the paper pan under the platen should have rollers in them
Posted on Nov 29, 2008
VERNA GAUTHIER
SOURCE: Smith Corona 300 DLE--toggle from italics to normal type
SMITH CORONA TYPEWRITER 250 DLE. HOW DO I SPACE 1 AND HALF FOR TYPING?
Posted on Nov 28, 2011
How do you remove a back door panel on a 2004 Chrysler concord lx
There are panel holders made of plastic which hold the panel in and surround the door. Get at least two larger flat tipped screwdrivers, or a smaller pry bar and screwdriver, also a putty knife can aid in keeping scratches off the door
After removing the screws from the handle/armrest, remove the bolt from the latch, it has a little spring tension on it so you will need to hold it open with a screwdriver when installing.
Be careful to not scratch the door with the screwdriver by sliding
Once these are off, start on the rear bottom of the door and slowly work a flat tip screwdriver under the panel between the door and panel. (there is usually sticky tape and paper in between also).
Use a flashlight and while prying, locate the holder nearest the panel corner you are working. Once you locate the holder, pry the door panel away from the door right against the holder. Once you get it started it is easy to work the bottom and sides of the panel off the door.
Once the holders are out, the panel pulls up with plastic guides at the top against the window. When re installing the panel, ensure the guides are aligned before pressing them back into place.
Mar 13, 2015 | 2004 Chrysler Concorde
WHY SMITH CORONA 250 DLE DOES NOT SPACE BETWEEN LINES?
Usually there is an adjusting knob at the end of the roller where the paper goes down. It turns while hold the other end.
Sep 01, 2014 | Office Equipment & Supplies
Why does paper not advance to next line when carriage returns?
There might be a setting for how many lines it moves when the carriage gets to the end. It is mechanical so you'll see it!
Do you know where i can get a platen knob for smith corona 350 DLE
Google smith corona Dunkirk NY this will lead you tu a dealer that will be able to help you.
DickyO
Jan 15, 2013 | Smith Corona Office Equipment & Supplies
Google smitrh corona dunkirk ny they have most everything SCM.
DickyO
Jan 15, 2013 | Smith Corona Wordsmith 100 Typewriter
Need manual for use of smith corona model 250 DLE
YOU ARE NOT HELPING WITH ANSWER??????? WHY?????? I NEED TO KNOW HOW TO GET A MANUAL FOR USE OF SMI9TH CORONA MODEL 250 DLE. CAN YOU PLEASE ANSWER
Nov 05, 2011 | Smith Corona Wordsmith 200 Typewriter
How do you replace the door handle
take off the inside door panel and look for the screws or nuts that hold the handle in place and take them out. then you onhook the metal bars from the handle. you have to pop the bar out by turning the plastic piece and then pull it out of the holder
May 23, 2011 | 1999 Chevrolet Silverado 1500
To switch fonts on this typewriter, you need to change the letter wheel. Unfortunately, there is no practical way to change the letter wheel in the middle of a document.
Apr 10, 2009 | Smith Corona Office Equipment & Supplies
Smith Corona 235 DLE doesn't advance
Does the platen move or does the paper not advance? Check the paper release lever to make sure the feed wheels are snapped in place. If the platen does not move something in the paper feed motor area.
Jul 28, 2008 | Smith Corona Wordsmith 200 Typewriter
Jun 26, 2008 | Smith Corona Wordsmith 200 Typewriter
Smith Corona Typewriter - 350 DLE - Refurbished 350DLE with New Machine Warrant Logo
173 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
STEVE SPAM REMOVER
ray gallant
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
