Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
Chris Posted on Apr 30, 2012
6700 rev c, aqualink rs
All lights are on controller, no communication
4 Related Answers
Anonymous
  • 125 Answers
  • Posted on Feb 26, 2009
SOURCE: inside control panel displays 6522 rev GG
Aqualink Guide book
Anonymous
  • Posted on May 28, 2009
SOURCE: Why am I getting a 6700 REV C message on my AquaLink RS6 home spa
I had the same issue, but only after I pressed the reset button on the side of the panel. After a couple of days of troubleshooting, I found a small nick in the wiring from the outdoor unit to the indoor paneI. I turned off the breakers to the pool equipment, rerouted a new cat5 cable, but cat3 will work just as well, wired it up and all was good. A local pool guy wanted to charge me about $2000 to replace both units. I spent less than $5.
Good luck
joespools200
  • 246 Answers
  • Posted on Sep 13, 2009
SOURCE: After lightening strike, Aqualink control panel
ok check all the braker even the one for the house .turn them off all and back on if this do not fix check for 220 v if voltage is present the board is bad need replacement get the number from the back to check for prices
Anonymous
  • 990 Answers
  • Posted on Nov 03, 2009
SOURCE: the panel back light on myh Aqualink RS All
I don't think so but go through your menu to see if the backlight is enabled. I have never heard of one burning out unless a surge or something fried the whole unit.
Testimonial: "To my surprise, it was not enabled, and that was the problem. I don't know how it got disabled, because it has been on for 7 years, but. . .Thanks!"
All lights are on the control panel. The message reads"6700 REVC" can't turn anything on or off.
Most likely a problem in the RS-485 communication between inside and outside Circuit boards.
Email [email protected] for Help
I have a a rs16 and the screen says 6700 rev c what does that mean
check to see if wiring from aqualink to house isnt cut or damaged also check the red 4 pin connectors 1 inside controller make sure no wire ends touching each other or off then check the one inside the aqualink top panel
My Jandy Aqualink, all the buttons are lite up and the display says 6700 REV C
This is a common problem with the communication between the RS Aqualink remotes and power centers. These can be fixed quickly and reliably at www.fixyourboard.com
After lightening strike, Aqualink control panel reads 6700 rev c. All lights on, none work. Outside, power center won't work. No lights. Reset doesn't work. Battery good, fuse appears good. Any ideas?
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
ZJ Limited
ZJ Limited
john h
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
