LG LFD25860TT Titanium French Door Refrigerator Logo
Question about LG LFD25860TT Titanium French Door Refrigerator
LFX 28978 LG French door refrigirator too warm, frost in the back of freezer
Anonymous
    New Friend:
  • 183 Answers
Call for service, could be a computer board, fan motor, or defrost system. cheaper in the long run to call for service
Posted on Apr 30, 2012
  • Anonymous May 07, 2012
    I called for service but they cancelled the appointment at the last minute. So, I cleaned out my refrigerator by taking all the foods from refrigator and freezer out totally, unplugged the refrigerator, gave the inside a throughout cleaning with a damp towel and let it stay unplugged overnight about 10 hours. Then, I plugged it back adjusted the temperature for the frig at 37 degree F, and the freezer 0 degree F. Voila, it started cooling again. I left a thermometer in the frig and checked back in 24hrs, the temperature went back to 37 degree F as the normal level. The frost in the freezer was gone. Now, I have my refrigator working again.
5 Related Answers
Anonymous
  • 828 Answers
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Posted on Jul 31, 2008
Anonymous
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
CongressmanT
  • 8 Answers
SOURCE: My LG bottom freezer, french door evaporator fan
Defrost heaters are not coming on. Check with multi meter..is it frost, or ice freezing under the fan-blades. That my friend is a blocked drain hole. Otherwise ohm out defrost heater should read 30to69 ohms of resistance. Timer may be stuck, or a hi-temp safety switch is not closing (a small disc at the top of the coils) when it comes out of defrost. Carweful with that gun, Jim! Too much heat warps all that chinese plastic. Chris in bigbEar
Posted on Apr 20, 2009
Anonymous
  • 76 Answers
SOURCE: fan runs all the time - freezer frost build up
The fan should cycle during recovery period after you opened the unit and then shut off. Make sure there is plenty of space around the unit for ventilation. If you've done this and you said it's 3 months old? Call for warrantee service.
Posted on Jul 26, 2009
Anonymous
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
How do i manually defrost an LG French door, bottom freezer, refrigerator?
same way but use a fan as well to blow the warm air into the freezer
2answers
I have some frost on back wall and some food freezes now and then.
Assumeing you are saying frost on the back wall of the refigirator, I would increase the temperature for the refrigirator area. If that does not help you may have problems with the defrost system.
2answers
I have an LG refrig french door model LFX 31925ST/00. Purchased less than 2 months ago. The top plastic freezer door continues to get an ice build up on the front of the drawer only. Is this normal? ...
It sounds like a loose or bad seal on the top area of the freezer door. Use the old dollar bill test to see how good the seal is. Hold a dollar bill up to the seal and close the door. there should be some resistance. compare the resistance between the top and bottom of the door.
Frost on back wall of freezer
There is a door that is not closing 100% of the time. There is warm moist air entering the fridge and building up on the back wall.
Make sure all doors are closing. Sometime the bottom door will close on one side but not the other.
Good Luck.
1helpful
LG LFX 25950SB, the Ice Maker is not working, just hear a click
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
klh
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
