I would like to operate a URC22B universal remote with my Bush BTVD31187S2 television but do not know the code or how to input to the remote as I have no manual and cannot find the URC web site. Can anyone help please?
SOURCE: Emerson Jumbo universal remote not working with Insignia LCD tv
The code is under Sansui. It's code 135. Don't ask why. But it works and fully functional.
as soon as u bought the universal remote it came with a paper that say a bunch of codes find ur tv model go to set up look were u can put in the code and follow the code exact
SOURCE: ILO universal remote code
Buy an rca universal at wal mart (model rcr312w) $8.00 fix. Just follow the Auto Scan instructions, it worked for my 26" ilo today.
SOURCE: I have a URC22B universal remote controller. I do
tv codes .com
or remote controler codes .com
SOURCE: hi i have lost instruction
@font-face {
font-family: "Cambria";
}p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all
the codes listed for your brand, try searching for your code. The Search Method
allows you to find the code for your device by scanning through all the codes
contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are
working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong
code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
