Question about Timex IronMan Race Trainer Heart Rate Monitor Watch
Timex ironman race trainer heart rate monitor stops receiving data
My heart rate monitor works fine for the first 10 minutes of my run. After 10 minutes my watch reads, "NO DATA". It always seems to stop working at about 10 minutes into my runs. I have tried replacing the battery in the strap and had no success fixing this problem. Sometimes I can rub the heart rate strap a few times and press the heart rate button on the watch to get it to restart/show my heart rate but even when it does get going again it never lasts longer then 10 minutes.
Posted by mark woodward on
5 Related Answers
Anonymous
SOURCE: Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Posted on Jan 19, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: just purchased timex 1440sport watch with heart
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.If you can not sort the problem after following instructions, you may need to replace battery. Rate me, please
Posted on Mar 28, 2010
Anonymous
  • 184 Answers
SOURCE: strap broken on timex heart
Hi, Almost any large dealer like Wal-Mart, Sears, or Target will have Timex replacement straps and bands for most popular watches and monitors. Sometimes a local Authorized Dealer will have specialized products that the department stores don't even carry without ordering.
I have had good luck with Wal-Mart on watch accessories. I've also ordered straight from Timex in Little Rock, Arkansas, ph. 1-800-448-4639, but it usually takes more time for just parts.
Thanks, Bill
Posted on Sep 08, 2010
Azrael SRL
  • 11800 Answers
SOURCE: I have had my Timex
The heart rate is recorded at these abnormally low levels because the sensor has lost its sensibility. This can be caused by only 2 things:
1 - the battery for the watch is almost dried and its voltage has dropped so low that the sensor can't work no more. You will have to replace the battery. because your watch is a sealed type you should take it to a repair shop: they will know how to open it carefully enough as to not damage the rubber seals.; and if they can't open it without damage they will have replacement rings.
2 - the sensor itself (which basically is just a microphone that listens to the beats) is clogged by dirt. Wash the watch in hot soapy water and look very carefully for cracks in the rubber of the strap - if you find one then the sensor has been permanently damaged by the sweat that seeped in. In that case it's time for a new one.
Posted on Dec 15, 2010
Anonymous
SOURCE: Timex M515 Heartb Rate Monitor in correct readings
I´m experienced the same problem of incorrect readings after a long time without use. I cleaned the rubber parts of the chest strap with soap and water, than I use some silicone grease or other silicon liquid to keep the rubber hydrated. Make a careful cleaning in the contact area between the rubber and the plastic parts, the fissure in these area use to be full of "sweat dust".
Posted on Jan 05, 2011
Where is the reset button in my timex chest strap
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
Feb 14, 2011 | Timex Ironman Race Trainer Digital Heart...
How do i reset the Timex Zone Trainer Digital Heart Rate Monitor Watch T5J983 for each workout?
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
Nov 18, 2010 | Timex T5J983 Zone Trainer Digital Heart...
Strap broken on timex heart rate monitor watch 30 lap ironman triathlon need a replacement
Thanks, Bill
Sep 06, 2010 | Timex Ironman T59761 Midsize 30 Lap...
Manual of Timex Zone Heart Rate Monitor watch . Model T5H881F5
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Apr 14, 2010 | Timex T5J983 Zone Trainer Digital Heart...
I can't find a manual online for my model and I am trying to pair my heart rate monitor. Timex T5J983
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Dec 14, 2009 | Timex T5J983 Zone Trainer Digital Heart...
The resin straps on either side of my heart
Where can I take my son's Marcel Drucker to get the crystal face that was broken in pieces?
Sep 06, 2009 | Ironman 90 Timex Heart Rate Monitor Watch...
Timex Ironman 30 lap heart rate does not display
the battery type is written on the back of the watch.
Jul 12, 2009 | Timex Ironman Tri 30 Lap Sleek T59671...
How do tou reset the review function on a timex 30 lap ironman triathlon?
Yeah...it took me awhile to figure this one out too.
You can't actually reset the Review function back to zero. Instead, you replace the data with your latest workout.
Here are the steps:
1) turn on heart rate monitor
2) setup HRM zone
3) start chronograph
4) do your workout
5) stop chronograph
6) review your results
Starting the chronograph is the key. This is the step I missed
May 01, 2008 | Timex Watches
Timex IronMan Race Trainer Heart Rate Monitor Watch Logo
141 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
MrFixitSTTL
Are you a Timex Watch Expert? Answer questions, earn points and help others
