Acer Aspire 5920-6335 Laptop Logo
Anonymous Posted on Apr 29, 2012
Blu ray driver for acer aspire 5920
Device shows working properly but it wont play dvds or blu rays
August Brown
Level 3:
Genius:
  • Acer Master 1,652 Answers
  • Posted on Dec 08, 2021
August Brown
Acer Master
Level 3:
Genius:
Answers
1652
Questions
0
Helped
352052
Points
5096
You need to check whether it is the problem of your Blu-ray player or Blu-ray disc.
If your Blu-ray player hasn't been updated for a long time, then you should go to the official site of the Blu-ray player to download the latest firmware and update it.
If you Blu-ray player is physically damaged, then you have to buy a new one.
If the region codes of your Blu-ray player and Blu-ray discs don't match, then try to use Leawo Blu-ray Copy to remove the region code. Also, you can use this software to make physical Blu-ray to digital, so that you don't need to watch Blu-ray through the player.
Jesse Allen
Level 3:
Master:
  • Acer Master 307 Answers
  • Posted on Jul 03, 2018
Jesse Allen
Acer Master
Level 3:
Master:
Answers
307
Questions
0
Helped
160974
Points
1872
Maybe there's something wrong with the Blu-ray and DVD lasers. You might get the lasers replaced or get an external Blu-ray drive. Usually a Blu-ray drive can also read and play DVDs as well. Tip: you can get your Blu-ray/DVDs ripped to your laptop, it'll make watching them on your laptop easier. In case you need, here's how you can rip your Blu-ray/DVDs to your laptop: 2 Solutions to Rip and Convert Blu Ray Disc to Laptop
Anonymous
Level 2:
New Friend:
  • Expert 77 Answers
  • Posted on Apr 30, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
77
Questions
0
Helped
11680
Points
209
Alright dude check out this forum it might be of use to you:
http://forum.blu-ray.com/showthread.php?t=53144
hope it helps : )
5 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Jun 20, 2009
SOURCE: Can't get Blu-Ray DVDs to play through my Acer laptop to LCD TV
The specifications of this laptop states that it has a Dual layer DVD R/W drive. This drive can only play DVDs and CDs but not BluRay discs and it can burn single and dual layer DVDs and CDs.
Anonymous
  • 191 Answers
  • Posted on Oct 18, 2009
SOURCE: Driver of blu ray for my aspire 5536
The standard specs for all of the 5536 models show equipped with a Super-Multi drive which capable of many CD and DVD formats including double layer DVD. However, I don't see support for Blu-Ray.
You could add an external Blu-Ray that connects to USB or FireWire (1394).
Testimonial: "Thank you so much, I was very frustraded "
Anonymous
  • Posted on Feb 17, 2010
SOURCE: Aspire 6920g with optirac BD rom 5500, since i
its a firmware problem, im really struggling to find a replacement, but basically the sony optiarc BC-5500A is a discontinued model, and on the sony website, it gives u a firmware download, but its not an up to date one, im having problems installing it, http://www.sony-optiarc.eu/supportservice/downloads/bluraydrivesnotebooks/bc5500a.html
i hope it helps, but i dont kno if u need another version for Windows 7, cus as soon as i put it on i had the same problem as you.
Anonymous
  • 186 Answers
  • Posted on May 01, 2010
SOURCE: Windows 7, Blu Ray Disks not working
go to control panel check settings
Anonymous
  • 503 Answers
  • Posted on Jun 20, 2010
SOURCE: acer aspire 6935g wont play blu-ray discs, will
You need to download K Lite Codec Pack (Its Free) and you can install it via....... or you can try googling it.
http://www.codecguide.com/download_kl.htm
It contains all the different audio and video codecs. Your computer might not play it because it doesnt have a blue ray codec by default
Please post your feedback and Vote if the problem resolved as per your satisfaction.
My acer aspire 5920 wont play blu rays anymore the driver is there and says its working but it shows only a cd drive on the devices even though it shows the dvd rom in properties
Best first step is to make sure that you have the most current driver from Acer. If you are unsure if it's current just doenload the one that is right for your operating system.
Either way re-install the drive! (YES, even if it said that everything is operating correctly).
1helpful
My Aspire 6920G works great other than it wont play Blueray DVDs. I have been advised to download this cure ?. Acer Arcade Deluxe v1.13.4806. Will it work ?.
This is unlikely to help. Firstly a clarification. Blu-Ray discs and DVDs are two different types of discs. A standard DVD drive, found in more computers, cannot play Blu-Ray discs. Firstly, insure that your computer has a BR drive. In the case of a desktop PC, there should be a logo on the front of the drive that will indicate. In the case of laptops and netbooks, the logo should be on the bottom of the device. Otherwise you may check the device's properties in the Control Panel to be certain.
Assuming your device does support Blu-Ray, you must have special software to play it. The most common and well supported is Cyberlink's PowerDVD application. Despite the name, it plays BR discs are well. You can buy it at the Cyberlink website here:
http://www.cyberlink.com/products/powerdvd/overview_en_US.html
However, if your device has a BR capable drive, it's likely that BR software was included with it. Check any installation discs that came with your computing device.
4helpful
2answers
Can you burn blu ray with the acer aspire 6920g or do i have to buy external blu ray drive
The Matshita BD-CMB UJ-120 optical drive that comes with the notebook cannot burn blu-ray, only play them. It can burn DVDs.
1helpful
2answers
My Acer Aspire 5735z has no sound on dvds in Real
use the driver cd which came along with your laptop and reinstall the audio driver from it. After that reinstall the real player as well if needed.
After that everything should work fine.
I hope this is helpful to you.
Thanks
2answers
1helpful
3answers
I cannot play Blu Rays on my Acer (Vista) PC with
If the drive doesn't read any disc's you need to reinstall the drivers and verify you have the latest version. If the drive is ONLY having trouble with Blu-ray then i'm assuming it's the player that you're using; it may not have the right Codac's etc. Also, try multiple Blu-ray movies to verify it isn't just the one movie.
2answers
Acer Aspire 5920 fitted with Blue ray drive : It plays NO blue rays or other DVDs. Regional codes are set properly. It though burns CDs What can I do ? Andreas
What operating system are you using? It sounds like you need to install the drivers for it.Because the machine will know its a cdrom first but it needs drivers to read DVD and the codex to read and write
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
