Hi, I have a side by side double fridge freezer (from america originally). It is about 12 years old and works generally quite well apart from one big problem...There is always a major ice build up that forms in the freezer at the bottom, water also then leaks from there to the floor but it is the major ice build up at the bottom which is a big problem! I have seen other posts about this where blocked drain hole at the back of the freezer is the problem which u need to pour warm water down to unclog ...but i have no drain hole visible in my freezer and at the back is a white panel which is screwed on with white caps (I can't use screwdriver to unscrew them as they are not screws but caps!)..so i can not get to the drain hole (if that is the problem) as it is behind this panel...please someone help! what can i do? My fridge model number is GS2326CEDW/11 Serial number is S11601107UW Admiral side by side fridge freezer..if anyone knows this model and how to fix this problem, please let me know...
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: FRIGIDAIRE FRS20ZRGD7 (SIDE BY SIDE) WARM FRIDGE/ COLD FREEZER HELP!
look open the freezer door pull the lower kick plate off look for a small little hole there its a mechanical timer model should be close to the wheel in that hole will be a plastic piece open the freezer door you will hear the fan running in the freezer take out the four or five screws on the lower panel where you keep seeing the frost and remove it you will see a silver honeycomb looking piece that's the evaporator on one of the tubes will be clipped a silver dome looking piece with two wires on it that's the defrost thermostat now turn the timer with a screwdriver that's the piece in the little hole slowly to your right till you hear a click and the fan stops in the freezer now as your turning it it will make a ratchet sound you want the click and the fan to stop look at your watch and note the time then wait about 5 minutes and look at the heater to see if its on if its all frosted up the frosted should look all watery if the heater is on then just let it run if not then reach up and turn the freezer control to the off position then un plug the two wires on the defrost thermostat and take the two wires that you unplugged the thermostat from and plug them back together and turn the freezer control back on and wait stay there and watch the heater come on let it defrost the evaporator if the heater comes on when you do that .that means the thermostat is bad if the heater comes on without you having to by pass it that means the timer is bad if you do all that and the heater does not come on then the heater element is bad now its going to get red like an oven and pop and sizzle but don't let it freak you out now if you had to by pass the thermostat and the timer cuts the compressor on before the frost is all clear just turn the timer around again till the fan cuts off and the heater will come back on if you by passed the thermostat then when all the frost is melted then reach up and turn the freezer control back off and reconnect the thermostat.Now after about 30 mins after turning it off the timer should cut back on if its not bad when you change the timer back out the two screws reach under the fridge and turn the timer and its shield till the screws are in the removal position when the timer is loose remove the shield and unplug the timer plug your new one back in then put the shield back on and back where it goes now id recommend changing both the timer and the thermostat as they fail pretty close together the stuff i described above is to make the unit defrost to save your food with out having to use your hair dryer also when all the frost is melted at he bottom of the evaporator on the right hand side is a hole in the cabinet that has to be clear of frost for the fridge to cool properly now any time during this defrost technique if you have a problem turning off the freezer cold control will turn off the defrost system too if i can be of help or you need to know something just reply to this post
SOURCE: F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
SOURCE: Water colecting on floor of freezer in
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
SOURCE: Kenmore refrig model 10671182101 water leaking in the interior
iced up drain , clean and defrost drain
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
