I have just moved into a rented property which has a Belling Oven installed but I can't work out how to use the timer / clock. Is there any instructions I can download. The oven is a Belling Synergie model XOU252SS type FM 60-2. Any help would be much appreciated Thanks James
SOURCE: how to adjust clock? no Instruction manual!
I had the same problem... NO MANUAL.. I contacted Newworld who posted me a hard copy manual. I have scanned the manual into a PDF document. If anyone needs a copy, please email me at [email protected] and I will email you the manual. Happy Cooking
SOURCE: How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
SOURCE: can't get my belling oven to work
Press & hold both the 'Cook Time' and 'Stop Time' buttons together and, while holding both of them down, press either the + or - button (this is the way to set the time of day). Release all buttons simultaneously. This should enable the cooking functions to operate.
SOURCE: fan oven option not functioning on main oven
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
SOURCE: How do I set clock on Belling Synergie
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
To set the clock
hold the cook and stop buttons together at the same time
then use the up and down arrows or+/- to set the time in 24 hour format
