Question about Lands Phones
How to record in DISA in panasonic pabx tes824
Posted by raaj_raja on
Carl Navarro
  • Lands Phones Master
  • 2,460 Answers
From the phone connected to Jack 01, press PROGRAM and dial 91 + the DISA OGM number. In most cases it will be #1.
Carl
Posted on Apr 29, 2012
ANISH
    New Friend:
Panasonic ogm card how to record voice then save
Posted on Apr 21, 2013
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: How do I change the time on my KX-T7730 telephone.
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset still on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done.
Please rate this answer if it was helpful.
Thank you.
Posted on Mar 23, 2010
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: I have a 824 ans
My 824 has a DISA card already in it. What did the manual say? It has comprehensive instrucitons on how to use DISA and how to record the OGM. Try PROGRAM 911 from extension 101.
As far as the secondary greetings, I guess they would be in 912 and 913.
Activation and deactivation is part of ring assignment to trunks.
Carl
Posted on Jan 20, 2011
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Hello friends from FIXYA, I have a situation
And??? What's the problem? My DISA is set for 1s on the first page and it never rings a phone. If you want it to answer the outside line on the first ring, you'll have to turn OFF Caller-ID. Now it will answer right after the first ring, but you lose CID logging.
On my working system, the DISA 6.1 section is with AA and 1 second, and 6.2 the first two timers are 3 and 5 seconds. In 9.1 you can uncheck CID but I don't recommend it.
Carl
Posted on Sep 22, 2010
Testimonial: "Dear Carl, I really appreciate your input. My concern was that increases wait time on my clients. Now I know what I have to loose. THANK YOU ALOT."
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: how do i programme extension
It comes already programmed for lines, so you must be looking to program buttons for other things. How's that OM working for you? I can link you to the US version, it will program the same but you'll have different descriptions. Start on page 153 "Customizing your phone" :-) http://www.public.carl.airpost.net/Pana/TA-824/200_TA_OM_07-04%5B1%5D.pdf
Basically, you will press PROGRAM and buttons and use 1 + ext STORE for extensions and the right side buttons will be just access codes. Here we get an outside line with "9" and the phone numbers.
Carl
Posted on Apr 04, 2011
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: how to assign password for the extension not to make international calls
It's not a password, it's a restriction. You change the Class of Service for the phone and put in the international code as a restricted digit.
Check your Programming manual for the system.
Carl
Posted on Nov 27, 2011
Panasonic tes824 pinouts for TNG buffer
Try the parts department for your device at Panasonic . Com. support and parts.
May 10, 2014 | Computers & Internet
Our company uses the PANASONIC KX-T7730 phone system, just wanting to know if customers can call directly to our extension numbers?
if your pbx has a built in disa feature, then you need to program
the DIL (sys. pgm. # 418) to DISA-OGM 1. Then you need to
record an OGM (program 9,1,1) to tell you customers that
they can dial the ext.# directly.
Oct 29, 2013 | Panasonic KX-T7730 Corded Phone
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
I have lost my programming password of Panasonic KX TES824. How can I Reset the Password?
i try to reset this pabx panasonic 308 many times but not totally reset theres is no other way to reset them..i turn on pabx and sw to clear position and pressing reset button but not back to default value..i need ur advice thanks and god bless
Mar 25, 2012 | Lands Phones
How to assign password for the extension not to make international calls
Carl
Nov 26, 2011 | Panasonic KX-T7730 Corded Phone
We have a new KXTES824 which we are setting up here with a mix of KXT7730 and SLT phones. We've done this before without incident but have an odd problem. We have a single phone connected (PT) and...
One of the ports is shorted or you have the DISA turned on. Start by dialing each extension 101-1xx on the 824 and make sure that none of them are tripping the ring. You'll probably find that one of the ports is bad, the wiring is bad, or there is a programming issue. IIRC the U.K. system is not delivered with DISA, but you may have installed or turned on that feature.
Carl
Feb 03, 2011 | Panasonic Lands Phones
I have a 824 ans just got a DISA card I need to program the DISA card Please advice if you can answer the following Question 1) How/what is the program code to record greeting message(msg 1 to 3) 2)...
Carl
Jan 20, 2011 | Panasonic KX-TA824PK Phone
How do I update the time on the panasonic kx-t7730
that is not pssible to set from telephone
there is a PABX device (panasonic kx-tes824 ) fixed in wall
from that PABX check 101 extension number (maybe 10, wich phone connected jack1 )
from there is only you can program
Please let me know this useful
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
Hi everyone, I have got a panasonic KX TES824 system. The guy before me changed the default password of the system. How do i reset the password? I tried opening the box and i see two buttons. one...
First the button clear position
anfter press hold reset 20sec
it will reset
after turn off PABX
move the button to open position
and strat the PABX
Please let me know this is helpful
Lands Phones Logo
7,743 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
