Is there any way to get my tv channel back on 4 with no remote?
Adding details will get you a faster solution from experts. I have a Magnavox tv/dvd combo and Verizon FIOS. I could not get the FIOS universal remote to program the tv itself and was turning the power on/off manually. (I also could not get a 'cheapy' univ. remote to program, the orig. remote lost in a move) The tv was inadvertently changed from channel '3' to '4' via the cable box. Manually, the channels can only be changed from '2' to 'AUX'. My question: is there any way I can get my tv back on channel '4'?
Posted by skelectric on
    Top Expert:
  • Televison & ... Master
  • 76,455 Answers
Try after amke a factory reset to your tV. Normally, aits remote control is needed to make it channel-4.
Posted on Apr 30, 2012
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Samsung BP59-00071B remote wont program Sanyo VCR DVD combo
Try 543. thats what I need to record to my Sanyo VCR via Bell ExpressVu satellite receiver.
Posted on Feb 25, 2009
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: my appliances need codes
Each of the makers of the products you mention have this on their website,
if you don't have the manual for the universal remote then
http://www.jascoproducts.com/support/universal-Remote-codes.asp
it has the codes
Posted on Feb 04, 2008
Anonymous
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
Anonymous
SOURCE: Synergy V remote - TV power on to last channel viewed - what's the code??
Actually, there is a setting in the cable box for this. You hit the settings button on the remote TWICE, then scroll down to Viewer:Power On. Click on what channel (or last channel) you want it to go to when you power on. Hope this helps. I have the 8300 HDC DVR.
Posted on Jan 12, 2009
Big Hev
Dennis
  • 64 Answers
SOURCE: I bought a Jumbo Universal Remote but need codes not listed in manual
The Motorola code is 0120. The Samsung codes are 0517, 0600, 0847, 0926, 1071, 1102.
If these are not doin' it for you, then go here.
http://www22.verizon.com/nroneretail/nr/rdonlyres/0d93f875-4498-460f-8fc4-a15d519b4e7c/0/welcomekitremotecontrolinsrt_nc.pdf
Have fun with your gigantic clicker... And the remote, too! lol
Posted on May 30, 2009
I have a Magnavox TV/DVD combo #MWC13D5 Also a Magnavox converter box #TB110MW9 no TV remote but converter remote TV has two channels that is parent blocked can the converter remote fix the block I can...
With the converter remote control, you can't unblock the TV. To unblock it, you should have the remote control to the TV.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 29, 2014 | Televison & Video
My 1996 Magnavox 25" TV won't work
It sounds that the tuner to your TV is faulty. A detail check is necessary to confirm. Seek expert tech support.
Jun 20, 2012 | Philips Magnavox 13MT143S 13" TV
Magnavox 20MC4304 20" TV/DVD/VCR Combo Remote:
A universal remote should solve your problem. You should be able to find one on ebay. You may even be able to find one for your particular TV on ebay as well.
Dec 03, 2017 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
I only have cable tv. when i connect my magna avox
This unit does not have a tuner to receive TV broadcasting. If you have the owners manual on page 26 it explains this. If you do not have the manual here is a link to one.
http://www.magnavox.com/pdf/mn/DV220MW9_mn.pdf
Sep 05, 2009 | Philips Televison & Video
Can't get CH. 3 or 4 on older Magnavox TV to hook in convert. box
HAVE YOU TRIED GOING BACK TO YOUR MENU AND SELECTING AUTO CHANNEL SEARCH LIKE YOU DO WHEN YOU PROGRAM YOUR TV FOR THE FIRST TIME TO GET THE CHANNELS IN YOUR SERVICE AREA? IT SHOULD PULL IN CHANNELS 3 & 4 (PARDON THE CAPS)
May 05, 2009 | Philips Magnavox DVD/VCR Dual Player
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Channel select
PUT YOUR TV ON 3 BUT MAKE SURE ON YOUR REMOTE FOR DVD PLAYER YOU PUSH THE DVD BUTTON .NOT THE TV
Aug 01, 2008 | Philips Magnavox MWR10D6 DVD Recorder
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
218 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
