I CAN NOT CLICK PHOTOS. THE SHUTTER RELEASE BUTTON HAS STOPPED WORKING. THE MSG DISPLAYED ON LCD IS " ERROR. PRESS SHUTTER RELEASE BUTTON AGAIN". PLZ HELP
Most likely cause is failure of the motor in the SQ unit on the side of the mirror box. This ***** the shutter, raises the mirror, and operates the aperture unit. They're made in China, motors are **** This is a very very common problem, and the part is always on back order at Nikon. As Nikon has announced that they are going to stop selling parts - to anyone - in a couple of months you are probably better off sending it to them. Be prepared for a bill a little less than $200.
also if you pressed down really ******* the release to get it to fire, you may also have broken the release switch
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
SOURCE: faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
