Question about Electrolux Washing Machines
I have the same problem "no power at all" when plug into the power wall inlet. No lamp on, display is blank/no led of 7 segments lit, nothing. The door can be opened and closed normally. Holding Delay and Extra Rinses buttons when power on the electrolux EWF 1074, doesn't help either. The electricity wall plug in is active. What can I do more ?
Posted on Jun 07, 2019
SOURCE: Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Posted on Aug 19, 2009
SOURCE: i have a ectrolux ewf 1074 with the padlock symbol
you need to turn machine on and hold the option and extra rinse buttons simultaneously for 6 seconds, the symbol will go and you'll be able to use your machine again as usual
SOURCE: Hi, I have an Electrolux EWF 1074 front loader.
Go back and check your connections. If you had the machine working previously and none of these issues were there before you cleaned out the drain area of the unit then your first step would be to check the connection to the pump as well as your connections going from the control to the door area as well. If after you have checked all your connections to the pump the door lock assembly, the control and the touch pad the unit is still doing the same thing then message me back. Before you do any of the checking of connections in the unit first hold down delay and extra rinse buttons together for 3-5 seconds. This usually will unlock the control if the control is locked on the unit. Also if the delay and extra rinse and the checking of your connections does not solve your issue then also message me back with the number of times the pause button is flashing and how often it flashes as well. If you have any further questions message me those back as well. I await your reply Thanks again Rick
Posted on Jul 18, 2011
SOURCE: My electrolux EWF 1074 washing
Hi First
make sure that nothing is blocking the drain pump assembly located inside the
bottom of the unit, after this test the door lock-switch assembly. If the door
lock-switch is also fine then the control board should be replaced. Hope this
helps...please post back for further assistance. Daniel
Posted on Sep 12, 2011
SOURCE: Electrolux EWF 1074 - the white plug won't come
Just had the exact same problem. Thought maybe it wasn't supposed to budge, but I got the pliers in there, and out it came!
Posted on Oct 04, 2011
