Right side park light does not work, but bulb is good.
SOURCE: Mercedes C Class w203 side light bulb
Hi rogergilliant,
Joe here, The best way to remove the side light bulb is to go threw threw the inside. Have to remove the under front fender lining. There is a clip to remove the housing, but the best way to not damage anything is to go from underneath.
SOURCE: brake lamp left,brake lamp right,brake left
HI, There is a problem with your tail lamp assemblies. Mercedes has recognized the problem and came out with a safety recall for this situation. Check with your local dealer to see if they are covered under warranty.
SOURCE: Ballpark price on 2007 Mercedes Benz C230 Maintenance B
The dealer near me charges $365 for a 4-cyl, $395 for a 6/8 cyl, or $425 for a 12-cyl. The only actual repair/maintenance you get for that price is an oil change (with Mobil1 and the MB filter, which are CRITICAL, ~$120 on its own) and tire rotation. This makes a lot of people think it's a scam, but really, it's a little steep, but definitely worth doing. The rest of the service consists of a massive inspection of your vehicle covering the following items.
-- Fluid levels
-- Tire tread/pressure/wheel condition
-- Air filter (inc. clean out housing)
-- Cabin air filter (inc. clean out housing)
-- Lubricate sunroof rails, locks, hinges, and seals on body.
-- Drive belt and tensioner
-- HVAC system operation
-- Instruments, cruise control
-- Wipers/washers/lights/horn
-- Windows/sunroof operation
-- Hoses
-- Transmission fluid
-- Brakes
-- Chassis/suspension
-- Driveshaft, inc. flex discs
-- Road test
-- Reset maintenance light
This is actually pretty essential to do, despite seeming like a lot of money for not much work. I have very rarely done one without catching a few things that the customer needs, and often it was a problem that would have gotten far worse had it been left to its own.
SOURCE: I have 1999 Mercedes Benz e300 Turbo Diesel and
Hi there
Its probably not a fuse issue as that would affect both sides.
when you replace a blub especially the brake lights it is possible to deform that nice flat panel of metalic strips and if you look carefully it sometimes breaks the plastic pins on which it sits, this causes poor connection to the functional bulb, the soloution is easy, get a small piece of card and fold it over till its about 2-3 mm thick then wedge it behind the panel of strips (top outside corner for brake light) and hey presto the light should work again, top tip use an umbrella and the electric seat to make sure the brake pedal is deppressed to check if alone.
SOURCE: engine oil light came on, on my mercedes ML 350, 2006 model.
IT MEANS THAT YOUR OIL LEVEL IS VERY LOW AND NEEDS TO BE FILLED. CHECK THE OIL LEVEL WITH THE DIPSTICK IF EQUIPPED. IF NOT, THEN ADD 1 OR 2 QUARTS OF OIL TO SEE IF THE OIL LIGHT GOES OFF. IT MAY TAKE SYNTHETIC OIL SO DON'T PUT CONVENTIONAL OIL IN IT IF YOU SEE A MOBIL 1 SYNTHETIC OIL RECOMMENDATION STICKER UNDER THE HOOD. IF YOU ARE UNSURE THEN BRING IT TO A QUALIFIED TECHNICIAN A.S.A.P.. HOPE THIS HELPS. GOOD LUCK.
