Recoton Advent Advent ADR-560 Remote Control Logo
Anonymous Posted on Apr 28, 2012
The code book
I need the paper work with all the different codes for tv's?
Level 3:
Top Expert:
  • Recoton Advent Master 76,851 Answers
  • Posted on Apr 29, 2012
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006956
Points
237762
Codes for Advent are:
0176 0922
Need the remote code for a venturer TV
0281,0288,0280. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
I have a RCA universal remote,I also have a code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Logik tv remote codes
2509,2500,2561,2538.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
2helpful
I dont know what ''line'' means on clubpenguin book codes
It means like if you write a line like this
line 2
line 3
line 4
like that
I need the Dish Network code for the Remote for Broksonic CTGV-5463GVC 19" TV. None of the codes in their book work.
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. Each of our different models of remotes have a few different codes that could work. I will list here for you the best codes for the more popular models of remotes that we have and the instructions for addressing the remote to the TV. I hope this information helps and if you have any further questions please let me know!
Remote Model #'s Codes for TV
3.0, 3.1, 3.2, 3.4 IR remotes - codes 720, 748, 752, 661.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 720, 748, 752, 656.
4.0 and 4.4 IR/UHF remotes - codes 720, 748, 752, 721, 656.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 720, 748, 752, 533, 656.
20.0 IR and 21.0 IR/UHF remotes - codes 834, 899, 750, 748, 533, 622, 754.
Instructions for addressing the remote to the TV
  1. Turn the Television On.
  2. Press and hold the TV mode button until all the mode lights light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Samsung UN46D6300 TV not in Logitec Harmony 700 remote database. Need IR code/s to enable controls (especially TV input source selection). Learning mode was only partially successful for power, volume...
When i went into the Harmony software, your TV did come up. If these codes aren't working try a different model Samsung (like UN46D6000). All new Samsungs use the same code set. If this still doesn't help, go to "Devices"->"Settings"->"Adjust Inputs"->"Method 3". Follow the directions from there. Something else that may help is Samsung calls it the "Source" button, Logitech calls it "Input x".
Need codes for a magnavox dvd player
Please provide the make and model of the remote too. Each remote manufacturer and model uses different coding. Many TV's now have universal settings, to which you need to look in the book from your TV to program the remote for your DVD player.
1helpful
I need the tv code number to get my remote
give me the brand tv so i can give yu the code numbers
3answers
1helpful
6answers
Codes
My book shows the following for Phillips:1003 1004 1008 1012 1019 1062 1068 1069 1074 1075 1076 1086 1087 1088 1089
Joy :)
Top Recoton Advent Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
