My phones screeen started going on and off but eventually would not come back on at all.i have replaced the slider flex as it was damaged and have also fitted a new screen.when turning on the phone everything else works fine but the screen willl only light up for a split second when pressing the buttons but goes off again.when the phone is on,when using the slider,this seems to have no effect with the screen and when pushing up or down ,the keys or screen do not light up either.can anyone help?????
SOURCE: TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
SOURCE: blinking lights
I left if off and unplugged for a few hours. When I plugged it in it started working again. My recommendation if this happens to you is to just unplug it all and let it stand for at least 4 hours and then plug it back in.
Good Luck
SOURCE: Power Failure! Help!
i HAD THE SAME PROBLEM BUT MY PS2 WOULDNT EVEN GO TO THE RED LIGHT BUT i PUT A 10 POUND WEIGHT ON IT THEN IT WORKED A GAIN UNTIL ONE DAY MY DAD OPENED IT UP AND MELTD SOME STUFF TOGETHER THEN i DIDNT EVEN NEED THE WEIGHT ANYMORE!
SOURCE: Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
