Question about Apple AirPort Extreme Router
My iPad won't connect to Airport Extreme WiFi
My iPad will no longer connect to my Airport extreme WiFi password protected network. I have no trouble connecting to that same network with my iMax.
Posted by James Henderson on
Darryl Sismil
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 22 Answers
Is your A P E a hidden network?, if so just type in the name of your router name and scan, it will find and ask for a password
Posted on Jan 21, 2014
5 Related Answers
Anonymous
SOURCE: Cannot get a PC to connect to my Airport Extreme BS
I had trouble connecting my PC to an airport network that my mac was working just fine on. I found this forum to get an "equivalent network password" and it worked great. The pictures were helpful too. Go to the Airport Utility and Then the "Base Station" header on your mac. Then select "Equivalent Network Password". It will be super long and lots of letters and numbers. Worked for me! Here is the forum: http://support.apple.com/kb/HT1790
Good luck, hope this helps!
Posted on Jul 02, 2009
Anonymous
  • 123 Answers
SOURCE: Can you get a different ip address for a laptop
Sure all you have to do is go to ipcomfig re;ease your ip addresses and renew. Once you do this the router should assign a different ip address.
Let me know if you have any problems.
Deathstalker
Posted on Aug 22, 2009
jgcalifornia
JG1977
  • 160 Answers
SOURCE: Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Posted on Aug 26, 2009
Joaquim Martins
  • 1127 Answers
SOURCE: airport extreme that is constantly flashing green
yes if only one location has this problem, the airport has now top security level because of latest theaths. it's normal.
Posted on Dec 29, 2009
dongkikz
Ferdinand Ecuacion
  • 440 Answers
SOURCE: Everything working fine until 9pm
Try doing a Trace Route on DOS ;
Open DOS - Start > click Run > type "cmd" = DOS
DOS COMMAND
tracert www.yahoo.com
IF THE RESULT WILL SHOW A " * " or timeouts then it is something to do with your line or if the response time is very high like 100ms 200ms 300ms then it is something to do with the line indeed ( normal = 1 ms - 50ms)
Posted on Mar 06, 2010
My wireless network will only allow one device on the net at a time.
most like the modem is faulty as you can have any number of devices operating together
is it a wifi modem with ethernet
make sure that you add each device by going to the add devices in the control panel
Mar 09, 2017 | Apple AirPort Extreme Base Station
Apple airport extreme stopped sending out a signal. no wifi pick up on any comp phone or ipad light is flashing amber. did a reset unplugged rest again noting
Go to your Airport utility, if you do not have it. download it in the app store. use the wizard setting, it will find your probles
Jul 03, 2011 | Apple AirPort Extreme Base Station Router
Airport Extreme, Mac Cube and proposed Blue Ray /WIFI
Yes, you just need to connect the Airport to the modem. That way, the Airport will fetch the internet connection and distribute it to all your WiFi enabled device. You don't need any other hardware. You just need to configure the airport using your Mac computer.
Here's a quick setup guide from Apple.com:
Setup Airport Extreme
Jul 23, 2010 | Apple Computers & Internet
I forgot my password and now I cannot connect with
if you need to recover a used wifi key, its not possible from within windows as they are all encrypted when added, you need to search for a wifi key recovery software, there are some that recover and back up keys used on the machine, so i would start there :)
for example
http://www.geckoandfly.com/2009/03/04/wifi-wep-wpa-security-key-password-finder-recovery-and-revealer/
Jun 23, 2009 | Apple AirPort Extreme Base Station
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Imac AirPort Extreme (0x14E4, 0x8C) to wifi
On the iMac choose Create Network... from the Airport menu. Then the Gateway laptop will be able to join the iMac's created network.
macs2u
Dec 29, 2008 | Apple AirPort Extreme Base Station...
Apple AirPort Extreme Router Logo
1,765 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Jeffrey Groves
Jeffrey Groves
Lee Hodgson
Lee Hodgson
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
