if it is a hid light system they are famous for the balast going bad. follow the wires from light bulb. if they go into a box then its a hid system and it is the balast box that needs to be replaced. also check the fuses, sometimes there are seperate fuses for each headlight.
Im assuming that you have check the fuses for the headlights and they are good.If your headlight is HID(Hight Intenstiy Discharge Xenon bulb) The headlight assembly will have a balast that might be defective.Deferentiating the Halogen from HID.Halogen will have a yellowish color when you turn on the headlights whereas the HID will have a whitesh to bluesh in color.If your clk320 does have a halogen then its highly probable you have an electrical problem but if its HID then you might want to replace the balast.
No, it is not easy to change the backlight on an LCD panel. The backlight is an integrated part of the LCD panel itself. The backlight for LCD monitors is also model and manufacturer specific, so there's no easy place to order a backlight to do it yourself. The good news is that your Samsung monitor should come standard with a 3 year warranty, so if it's less than 3 years old, you can call Samsung and they'll repair/replace it for free. If it's over 3 years old, then you may need to repalce the monitor... or pay to have it repaired.
You need to replace the balast as the voltages are buringing the bulb out and this is caused by a balast that is bad. The baslast is what the bulb connects to this has a sensor on it that relays voltages and heat back to the main control unit.
The problem may be related to the balast unit in your light fixture. Check under the cover plate in the middle of the fixture and look for a rectangular (usually black) box. If it has any brown liquid leaking from it then it definately needs to be replaced. Read the label on the box and record the values. Take your stats to the local electrical shop and buy a replacement balast. Installation will require the breaker to be shut off to the circuit. Be absolutely sure you match the wires before attaching them together. Disposal of the old balast must be done through your local recycling center. The material in some of these is quite dangerous.
I would problably suggest contacting an electrician if you are at all uncomfortable with handling a re-wiring job. Good luck with your situation.
