Question about Gestetner DSm615 Digital Imaging System
Como reset el sc 928 mp 161 ricoh - Gestetner DSm615 Digital Imaging System
Ngoro
    Top Expert:
  • Gestetner Master
  • 2,619 Answers
2 Related Answers
Anonymous
  • 126 Answers
SOURCE: machine shows a service code of sc 928
The SC - 928 is a Memory error problem.
The machine detects a discrepancy in
the write/read data during its write/read
test (done at power off/on and at
recovery from low power or night/off
mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes:
• Memory defective
• BICU defective
• Poor connection between BICU and
memory
The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
Posted on Jan 20, 2009
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: tengo bloqueada una fotocopiadora Ricoh Aficio 200
paper tray 3 motor error .. take the bottom cover off..open paper tray and then look at back and get another to close the tray check if the springs are broken or check the motor turns and lifts the tray up..
Posted on Jul 19, 2010
I have copier it given me this code SC 544 & SC 542 & SC 500 can you assist me please .
overload of the main motor or fusing unit (SC 500)
Look at your fusing unit, (rollers, thermistor, lamp, gears...)
and don't forget to reset SC code in SP mode.
Good luck
Jul 03, 2011 | Ricoh Aficio MP 161 Black and White Copier
I have a Ricoh 161 but after a firmware update erro (NIB) the machine tries to continue the update. How I cancel the firmware update or reset the firmware in the machine? ----------------- Eu tenho uma...
You can not stop a firmware update.
Did you turn the machine off while the firmware update? If you did that your NVram is broken
I think that the only chance you have is with a new NVram. Sorry but you will have to put a new NVram.
Jun 10, 2011 | Ricoh Aficio MP 161 Black and White Copier
Sc 335 da Ricoh 1075, como solucionar?
Olá!
Esse erro está relacionado com o Motor Poligonal do Laser.
Antes de mais deves actualizar o firmware da maquina. Existe uma referência que corrige esse sintoma.
Se depois da actualização o problema persistir poderá ser 1 destes problemas (por ordem de solução):
1-Mau contacto nos cabos do Motor Poligonal.
2-Motor Poligonal avariado.
3-Placa IPU avariada.
Espero ter ajudado.
See you!!!
Apr 01, 2011 | Ricoh Office Equipment & Supplies
TENHO UMA RICOH 161 E DEU O CODIGO SC 819
Isso é um erro de firmware.
Existe uma actualização que corrige isso. Se tiveres acesso a descarregar os firmwares e se souberes como fazer... O teu problema está resolvido.
Contudo aconselho que ligues com a assistencia tecnica. Contacta com a Ricoh portugal e eles enviam-te um tecnico que saberá fazer isso.
Boa sorte.
Mar 01, 2011 | Ricoh Aficio MP 161 Black and White Copier
SC550 Error. Ricoh MP 6500. Cleared Parts Exceding Target list. Reset 1902-001 on Copy SP. Still get SC 550 after power-up. ...Red "alert" light on, and red light on near "printer"...
That error code refers to the FUSING WEB END.
First of all you must see if the fusing web is end.
If the error occurs before the web ended you have to upgrade your firmware. There is a release firmware that corrects this symptom.
Feb 23, 2011 | Ricoh Aficio MP 161 Black and White Copier
Mi sumadora mp11dx esta como bloqueado "E 0" como solucionarlo
La Prensa CE/C buttom para borrar el error. Tomar una pequeña pen y, empuje suavemente en la pequeña reset agujero en la parte de atrás de la calculadora. Ahora, verifique y, asegúrese que el tipo impositivo y de tiempo es correcta. Puede que necesite para volver a entrar el tipo impositivo y tiempo.
Jan 10, 2011 | Canon MP-11DX Calculator
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
I have tried resetting ricoh aficio 161 showing error sc500, no luck , any offer of help appreciated
Main motor error SC 500 The main motor does not reach its operation speed within 0.7 second, or the main motor remains out of its operation speed for 0.7 second after reaching the operation speed. ?? Overload ?? Defective main motor
Apr 29, 2010 | Ricoh Aficio MP 2000 Black and White...
Tengo una Ricoh 1075 y me sale el mensaje de SC 541
press "clear" 1 - 0 - 7 and then Stop then turn off then back on
Jan 23, 2009 | Ricoh Aficio 450 Copier
322 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
