Philips 23PF5320 23 in. HD-Ready LCD Television Logo
Question about Philips 23PF5320 23 in. HD-Ready LCD Television
Conectar el computador al televisor philips 23PF5320 23 pulgadas
Quiero conectar mi computador con el televisor para ver películas o usarlo de monitor para trabajar, el TV tiene una entrada DVI. Compre el adaptador dvi/vga lo conecto al computador, pero no aparece nada. ¿Cómo hacerlo?
Posted by ana barcelona on
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
Anonymous
  • 476 Answers
SOURCE: Fuzzy picture with DVI input from NVIDIA PC Card
You need to set the PC screen resolution to as neear as possible to the TV's pixel resolution - 1366 x 768
Try 1360 x 768, or failing that, 1280 x 768.
Posted on Feb 16, 2008
Anonymous
  • 34 Answers
SOURCE: Connecting my MAC to my LCD TV!
Do you have a DVI port on the LCD screen? Please tell me what connections you have on your macbook and your TV. There may be a converter.
Normally HDTVs can only be hooked up through S video or DVI Depending on your video card.
Posted on Oct 24, 2008
Anonymous
  • 1284 Answers
SOURCE: now using an hdmi to dvi cable - screen size has reduced
Your digital box should have aspect settings as well. When watching HD TV and or movies there is a possibility to get the black bars on top and bottom. It all depends on the ratio it was filmed in.
Posted on Nov 19, 2008
Anonymous
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
Alcasas aver esto?
"Magallanes": cinco razones para ir a ver la pel?cula ' Cine ...
elcomercio.pe/.../magallanes-cinco-razone...
Translate this page
El ComercioAug 21, 2015 - Dami?n Alc?zar es el protagonista, con todo lo que eso implica: su ... Como dijo el director, es tal vez el cine un espacio donde esto pueda ...
Nunca pens? poder llegar a ver esto.... - Dimueble ...
https://www.facebook.com/.../10152594632655199
Translate this page
Nunca pens? poder llegar a ver esto. Lix, el l?piz con el que ... Itzcoatl Alcazar Edgar Tellez · August 8, 2014 at 7: ... Remove. Itzcoatl Alcazar Sandra Morales.
Baltasar del Alc?zar.
www.lcc.uma.es/~perez/sonetos/alcazar.html
Translate this page
Amor, no es para m? ya tu ejercicio,; Cansado estoy de haber sin Ti vivido,; Cercada est? mi alma de contrarios;; Di, rapaz mentiroso, ¿es esto cuanto ...
Luis Alc?zar puso a vibrar a todos con "Laura no est? ...
? 2:13
https://www.youtube.com/watch?v=CEn4IfJQw1A
Sep 28, 2015 - Uploaded by La Voz Per? Latina
Cada vez que vengo a ver otras nuevas audicione, siempre termino aqui en ... de aliento no saben cuan ...
Hola tengo un televisor proscan PLDED3273A-B NECESITO LOS CODIGOS PARA PROGRAR MI CONTROL DE DISH PORFAVOR
Alguien q me ayude y me diga q puchar para poner mi Tv en dvd quiero poner una pel?cula y no le encuentro al control donde se pone
2helpful
Necesito desbloquear mi nokia 2690
Hola, se puede desbloquear el m?vil por los c?digos de desbloqueo .. la forma m?s segura y mejor de desbloqueo es por los c?digos de desbloqueo y mi petici?n personal es que no van para el software de desbloqueo, porque a veces el software puede corromperse y que tus datos se perder?n debido a que, es mi mala experiencia, as? que fui para el desbloqueo de los c?digos de mobileunlocksolutions y unlocked.you tambi?n puede intentar, pero al ver que si su pa?s y el proveedor est? en la lista .. porque para algunos servicios s?lo est?n disponibles los c?digos .. ver con que y si el proveedor de su pa?s est? en la lista a continuaci?n, obtener los c?digos y desbloquear el m?vil ..
No puedo meterle videos
Hola martin diaza,
Por mas informacion, visita http://ow.ly/5PS6c.
Transferir el video del DVD al reproductor mediante el software Media Converter:
IMPORTANTE: La mayoría de DVD comerciales están protegidos por derechos de autor para evitar que se puedan convertir y transferir.
Para transferir vídeos al reproductor desde un DVD, siga el siguiente procedimiento:
1. Inserte el DVD en la unidad de DVD y reproduzca el vídeo en el ordenador para comprobar si se puede reproducir.
2. Inicie el programa Media Converter for Philips.
(Ubicación: Inicio --> Todos los programas --> Media Converter for Philips)
3. Haga clic en el botón Add DVD (Añadir DVD) de Media Converter.
4. Haga clic en el botón Browse (Examinar) y seleccione en la unidad de DVD de la lista el archivo que desee transferir.
5. Seleccione Main Movie (Película principal) en Media Converter y haga clic en OK (Aceptar).
6. Haga clic en START (Iniciar).
7. El vídeo convertido se guardará en el ordenador. Ahora podrá transferirlo al reproductor mediante Windows Media Player.
Para obtener más información sobre cómo transferir los archivos mediante Windows Media Player, visite:
www.microsoft.com/windows/windowsmedia/knowledgecenter/howto/mp11/sync.aspx
IMPORTANTE: En función de la potencia de procesamiento de su ordenador, la transferencia o conversión a un DVD puede durar varias horas.
1helpful
Se queda sin color la pantalla solo se ve la imagen pero sin colores sdolo en blanco es una magnavox de 32 pulgadas griz
Hello
Ya sea que est? viendo una pel?cula o un deportivo
caso, el televisor dispone de v?deo autom?tica
ajustes de control emparejados por su programa actual
de origen o contenido. La caracter?stica SmartPicture
restablece r?pidamente los controles de v?deo de su televisor para una
n?mero de diferentes tipos de programas y la visualizaci?n
condiciones que pueda tener en su casa. cada
SmartPicture configuraci?n se ajustan en f?brica para
ajustar autom?ticamente el brillo de la TV, el color,
Imagen, nitidez, tinte, la temperatura,
DNR, y los niveles de contraste +.
0.1 Pulse el bot?n inteligente de la imagen
en el control remoto. la corriente
Establecer SmartPicture aparecer? en la
centro de la pantalla.
2 Pulse el bot?n inteligente de la imagen
varias veces para seleccionar ya sea personal,
Pel?culas, deportes, d?bil
Se?al, o la configuraci?n MULTIMEDIA imagen
Aceptar
Como se pone el internet en el wii
Para conectar el internet a tu consola de Nintendo Wii te recomiendo ver el siguiente arcitulo publicado por Nintendo.com:
Para conectarte via WIFI
C?mo conectar tu consola Wii al Internet
Para conectarte con un cable ethernet
Wii - C?mo conectarse al internet
Si luego de seguir paso a paso esa guia sigues teniendo problemas de conectividad con tu consola verifica que tengas acceso a internet desde computadora para descartar problemas con tu proveedor de internet, tu modem o tu router.
De necesitar alguna sugerencia adicional puedes publicar mas detalles del "setup" que tienes en tu network para hacer un troubleshooting mas espec?fico.
2helpful
Porque sale prgsve
Entiendo que se establece la opci?n progresiva y ahora usted no est? consiguiendo nada en la pantalla del televisor. La opci?n Progresivo s?lo es aplicable para la interfaz de componentes (rojo, verde y azul). Es necesario ir a los elementos de men? para cambiar la opci?n de progresivo a entrelazado.
Por favor, conecte el reproductor de DVD al televisor mediante Composite (amarillo, rojo y blanco) o S-Video para obtener la visualizaci?n en la pantalla del televisor y cambie la resoluci?n de salida para entrelazar en la configuraci?n de salida de v?deo a resolver el problema te.
Nota: Cable compuesto se suministra con el reproductor de DVD.
Por favor, siga los pasos para acceder a la opci?n progresiva de los elementos del men?.
  1. Pulse Men? Inicio
  2. Seleccione Ajustes iniciales
  3. Navegar y encontrar la configuraci?n de salida de v?deo.
  4. Seleccionar componente en el marco de Configuraci?n de salida de v?deo.
  5. Seleccione entrelazado.
  6. Ahora usted puede conectar el reproductor al televisor mediante cable de componentes.
Si el problema persiste, por favor, siga los pasos para reiniciar el reproductor de DVD.
  • Encienda el reproductor en modo de espera y vaciar la bandeja de discos.
  • Usando los botones del panel frontal, mantenga pulsada la tecla STANDBY STOP y pulse / ON para encender el reproductor de nuevo.
Espero que esto deber?a resolver el problema.
Si el problema persiste o si necesita m?s ayuda, por favor, me preguntan. Estoy m?s que feliz de ayudarle. Gracias por la comprensi?n.
63helpful
5answers
Como programarla ala tv
Hola mi nombre es Mayra Diaz con Dish Network. Con much gusto le puedo ayudar a programar su control a su televisor. Primero que todo necesitamos saber cual es la marca de su televisor para darle los c?digos que funcionen con su televisor espec?ficamente.
28helpful
5answers
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger [email protected] Gracias es de Venezuela
Conectar JVC GR-DVM5 al ordenador con el sistema operativo Vista
necesito drivers para bajar videos desde mi camara jvc gr-dvm5 al computador que tiene windows vista home.alguien me puede ayudar con alguna informacion o sitio donde los puedo encontrar??
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
