My H61MXV when installed the audio driver still No audio device is installed even when rebted. How am i going to make it sound? XP and Win 7 doesn't work with the installer. is there any problem with the sound card?
Make sure you have speakers plugged in to the "Green" audio out socket. you can use a set of earphones if you have to. You then need to go into the control panel and set the Default audio device. Unless the device has a little yellow or red mark on it in the Device Manager. in which case you have more than likely got a failed audio chip. A PCI sound card will give sound output if the rest of the Motherboard is good.
SOURCE: installed xp, no audio
do you have any unknown devices in device manager? look for something with a yellow ? it should say multimedia controller. right click and update driver, then point the hardware wizard to the cd. if not go to bios then look for integrated peripherals then onboard audio, make sure it's enabled. then do the same as above.
SOURCE: Audio Installation for Foxconn G31MX motherboard
dowload the sound drivers
sound drivers ---> http://www.softwarepatch.com/utilities/ac97.html and http://www.softwarepatch.com/utilities/ac97.html
SOURCE: PCI Device Driver for FOXCONN 45CMV Series
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=45CMX&TypeID=en-us0000004
