Question about Microsoft Computers & Internet
Windows keeps shutting down unexpectedly
Windows shuts down without warning
Posted by Melissa Duplessis on
  • joecoolvette
    joecoolvette Apr 28, 2012
    1) Windows XP Pro? 2) What is the computer manufacturer name and model number? 3) Have you cleaned out the inside of the computer (Desktop), or had it cleaned? (Laptop) Post back in a Comment.  Regards, joecoolvette
  • RickandCathy Lee
    RickandCathy Lee May 04, 2018
    windows 7.. dell inspiron 570... no I have no clue where to start
Norman-Wynne Damstra
  • 1,179 Answers
Your computer is overheating, it is shutting itself down to prevent damage to the internal components.
Your computer should be serviced by a computer technician. He/she will clean the components and chassis of dust. This will increase airflow over the components, meaning your system will be stable and will not shut down unexpectedly.
Take care!
damnor01
Posted on Apr 28, 2012
5 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: windows explorer keeps shutting down
do a system restore to where it was working good for you.
Here is how:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
Posted on Dec 01, 2007
Anonymous
  • 7 Answers
Replace any Corrupt *.cpl file.
Posted on Dec 27, 2007
Anonymous
  • 32 Answers
SOURCE: Football Manager 2009 won't play
you need to run a full recovery on the system
Posted on Dec 28, 2008
abhvp
Abhay Pujari
  • 148 Answers
SOURCE: excel shuts down
Try running repair and do all the updates.
Posted on Jun 10, 2009
lmarrero
Lucas Marrero
  • 42 Answers
SOURCE: Presario desktop windows vista, shuts down unexpectedly
Windows Vista will not install on old computers. If this is your case try installing Windows XP, If this does not work you might want to try Linux (Ubuntu). which will run on almost any old computer with full capabilities.
It is free and you can download it from
http://www.ubuntu.com/
Posted on Aug 25, 2009
My Dell windows 10 will not log off circle keeps spinning
Usually, this means that something either running in the background, or an app, or an update trying to install is keeping the pc from shutting down. Wait about an hour if it is still just sitting there spinning you may want to do a hard power down.
WARNING forcing your pc to power off may have unexpected results not limited to unable to power up and lost data.
To force the pc down press and hold the power button until the unit switches off. Immediately restart the unit and do a thourough review to ensure proper operation.
2007 Road King Classic stalls unexpectedly when driving...no sputtering, just shuts down...starts back up whether stationary or driving...but no warning about cut off
Will the bike start up without turning off? If you have to turn ignition off then on again before it will start it may be the bank angle sensor gone faulty. This will set NO error codes in memory as it is NOT a recognised fault. ECU simply thinks bike has fallen over and shuts engine down.
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
My acer 5750 i7 keeps shutting down
The infected laptops encounter random shutdown problem until some maintenance activity is being performed on the system.
Two important things that you should do to fix a laptop which keeps shutting down are:
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes.
For an instant fix use system utility tool Reginout.
WebRepOverall ratingThis site has no rating(not enough votes)
1helpful
2answers
My laptop shut off after about 10 seconds
check the cooling fan if not running for if not the comouter will shut off
2helpful
Why does my computer keep shutting down?
Is Windows crashing or is it just shutting down without warning? If it is without warning, then I would suspect a failing power supply. May want to look at getting a replacement power supply.
Acer Aspire 5630 Laptop Unexpectedly Shuts Down
r u allowing the fan to intake air to cool down cooldown
1helpful
Unexpected shutdown with fresh battery ...only cycled 23 times so far. Mac shuts down after about 3 minutes....then shuts down on boot sequence after that. No warning...just shuts down instantly. Macbook...
"Shuts down instantly without warning" is the hallmark of a faulty battery. "All five lights on" is meaningless, as batteries with this fault go from 100% to 0% in a finger-snap. Assuming your battery is under warranty, it should be replaced at no charge.
Unexpected shutdown with new battery ...only
This is a duplicate submission -- I will be answering the other copy. Thanks.
Open Questions:
0answers
KYOCERA PRINTER Customer care Phone nUmber+1800 828 0294 Get easy steps to forgot or change KYOCERA PRINTER customer care rKYOCERA PRINTER via phone number 1800 828 0294 just follow some steps to recover KYOCERA PRINTER customer care while you want. In varoius conditions many people lost their account customer care and much more secure information or information may be hacked by anyone so in that case people want to configure KYOCERA PRINTER with KYOCERA PRINTER or other microsoft account services. Their are many certified officer to suggest people that how to change or rKYOCERA PRINTER KYOCERA PRINTER voicemail customer care using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to rKYOCERA PRINTER KYOCERA PRINTER customer care to rKYOCERA PRINTER or change it quickly, if you have any of them so contact to get well KYOCERA PRINTER care form us. KYOCERA PRINTER customer care rKYOCERA PRINTER not working XEROX PRINTERcustomer care rKYOCERA PRINTER phone number KYOCERA PRINTER customer care rKYOCERA PRINTER contact number KYOCERA PRINTER customer care rKYOCERA PRINTER help KYOCERA PRINTER customer care rKYOCERA PRINTER care KYOCERA PRINTER customer care rKYOCERA PRINTER wont work KYOCERA PRINTER customer care rKYOCERA PRINTER wont work KYOCERA PRINTER customer care rKYOCERA PRINTER link KYOCERA PRINTER customer care rKYOCERA PRINTER issues KYOCERA PRINTER customer care rKYOCERA PRINTER usa KYOCERA PRINTER customer care rKYOCERA PRINTER customer care service. XEROX PRINTERemail account customer care rKYOCERA PRINTER ' free KYOCERA PRINTER email customer care care ' cannot rKYOCERA PRINTER KYOCERA PRINTER email customer care ' KYOCERA PRINTER email customer care care ' KYOCERA PRINTER email customer care care download ' KYOCERA PRINTER email customer care care software ' free KYOCERA PRINTER email customer care care . KYOCERA PRINTER email customer care change, KYOCERA PRINTER email hacked customer care changed, KYOCERA PRINTER email hacked can't change customer care, change KYOCERA PRINTER email customer care on iphone, change KYOCERA PRINTER email customer care on ipad, change KYOCERA PRINTER email customer care on android, KYOCERA PRINTER email account hacked can't change customer care, how to change KYOCERA PRINTER email customer care on droid, KYOCERA PRINTER email customer care problems, KYOCERA PRINTER email customer care not working, KYOCERA PRINTER email account customer care rKYOCERA PRINTER.
0answers
TOSHIBA PRINTER Customer care Phone nUmber+1800 828 0294 Get easy steps to forgot or change TOSHIBA PRINTER customer care rTOSHIBA PRINTER via phone number 1800 828 0294 just follow some steps to recover TOSHIBA PRINTER customer care while you want. In varoius conditions many people lost their account customer care and much more secure information or information may be hacked by anyone so in that case people want to configure TOSHIBA PRINTER with TOSHIBA PRINTER or other microsoft account services. Their are many certified officer to suggest people that how to change or rTOSHIBA PRINTER TOSHIBA PRINTER voicemail customer care using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to rTOSHIBA PRINTER TOSHIBA PRINTER customer care to rTOSHIBA PRINTER or change it quickly, if you have any of them so contact to get well TOSHIBA PRINTER care form us. TOSHIBA PRINTER customer care rTOSHIBA PRINTER not working XEROX PRINTERcustomer care rTOSHIBA PRINTER phone number TOSHIBA PRINTER customer care rTOSHIBA PRINTER contact number TOSHIBA PRINTER customer care rTOSHIBA PRINTER help TOSHIBA PRINTER customer care rTOSHIBA PRINTER care TOSHIBA PRINTER customer care rTOSHIBA PRINTER wont work TOSHIBA PRINTER customer care rTOSHIBA PRINTER wont work TOSHIBA PRINTER customer care rTOSHIBA PRINTER link TOSHIBA PRINTER customer care rTOSHIBA PRINTER issues TOSHIBA PRINTER customer care rTOSHIBA PRINTER usa TOSHIBA PRINTER customer care rTOSHIBA PRINTER customer care service. XEROX PRINTERemail account customer care rTOSHIBA PRINTER ' free TOSHIBA PRINTER email customer care care ' cannot rTOSHIBA PRINTER TOSHIBA PRINTER email customer care ' TOSHIBA PRINTER email customer care care ' TOSHIBA PRINTER email customer care care download ' TOSHIBA PRINTER email customer care care software ' free TOSHIBA PRINTER email customer care care . TOSHIBA PRINTER email customer care change, TOSHIBA PRINTER email hacked customer care changed, TOSHIBA PRINTER email hacked can't change customer care, change TOSHIBA PRINTER email customer care on iphone, change TOSHIBA PRINTER email customer care on ipad, change TOSHIBA PRINTER email customer care on android, TOSHIBA PRINTER email account hacked can't change customer care, how to change TOSHIBA PRINTER email customer care on droid, TOSHIBA PRINTER email customer care problems, TOSHIBA PRINTER email customer care not working, TOSHIBA PRINTER email account customer care rTOSHIBA PRINTER.
0answers
EPSON PRINTER Customer care Phone nUmber+1800 828 0294 Get easy steps to forgot or change EPSON PRINTER customer care rEPSON PRINTER via phone number 1800 828 0294 just follow some steps to recover EPSON PRINTER customer care while you want. In varoius conditions many people lost their account customer care and much more secure information or information may be hacked by anyone so in that case people want to configure EPSON PRINTER with EPSON PRINTER or other microsoft account services. Their are many certified officer to suggest people that how to change or rEPSON PRINTER EPSON PRINTER voicemail customer care using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to rEPSON PRINTER EPSON PRINTER customer care to rEPSON PRINTER or change it quickly, if you have any of them so contact to get well EPSON PRINTER care form us. EPSON PRINTER customer care rEPSON PRINTER not working XEROX PRINTERcustomer care rEPSON PRINTER phone number EPSON PRINTER customer care rEPSON PRINTER contact number EPSON PRINTER customer care rEPSON PRINTER help EPSON PRINTER customer care rEPSON PRINTER care EPSON PRINTER customer care rEPSON PRINTER wont work EPSON PRINTER customer care rEPSON PRINTER wont work EPSON PRINTER customer care rEPSON PRINTER link EPSON PRINTER customer care rEPSON PRINTER issues EPSON PRINTER customer care rEPSON PRINTER usa EPSON PRINTER customer care rEPSON PRINTER customer care service. XEROX PRINTERemail account customer care rEPSON PRINTER ' free EPSON PRINTER email customer care care ' cannot rEPSON PRINTER EPSON PRINTER email customer care ' EPSON PRINTER email customer care care ' EPSON PRINTER email customer care care download ' EPSON PRINTER email customer care care software ' free EPSON PRINTER email customer care care . EPSON PRINTER email customer care change, EPSON PRINTER email hacked customer care changed, EPSON PRINTER email hacked can't change customer care, change EPSON PRINTER email customer care on iphone, change EPSON PRINTER email customer care on ipad, change EPSON PRINTER email customer care on android, EPSON PRINTER email account hacked can't change customer care, how to change EPSON PRINTER email customer care on droid, EPSON PRINTER email customer care problems, EPSON PRINTER email customer care not working, EPSON PRINTER email account customer care rEPSON PRINTER.
0answers
BROTHER PRINTER Customer care Phone nUmber+1800 828 0294 Get easy steps to forgot or change BROTHER PRINTER customer care rBROTHER PRINTER via phone number 1800 828 0294 just follow some steps to recover BROTHER PRINTER customer care while you want. In varoius conditions many people lost their account customer care and much more secure information or information may be hacked by anyone so in that case people want to configure BROTHER PRINTER with BROTHER PRINTER or other microsoft account services. Their are many certified officer to suggest people that how to change or rBROTHER PRINTER BROTHER PRINTER voicemail customer care using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to rBROTHER PRINTER BROTHER PRINTER customer care to rBROTHER PRINTER or change it quickly, if you have any of them so contact to get well BROTHER PRINTER care form us. BROTHER PRINTER customer care rBROTHER PRINTER not working XEROX PRINTERcustomer care rBROTHER PRINTER phone number BROTHER PRINTER customer care rBROTHER PRINTER contact number BROTHER PRINTER customer care rBROTHER PRINTER help BROTHER PRINTER customer care rBROTHER PRINTER care BROTHER PRINTER customer care rBROTHER PRINTER wont work BROTHER PRINTER customer care rBROTHER PRINTER wont work BROTHER PRINTER customer care rBROTHER PRINTER link BROTHER PRINTER customer care rBROTHER PRINTER issues BROTHER PRINTER customer care rBROTHER PRINTER usa BROTHER PRINTER customer care rBROTHER PRINTER customer care service. XEROX PRINTERemail account customer care rBROTHER PRINTER ' free BROTHER PRINTER email customer care care ' cannot rBROTHER PRINTER BROTHER PRINTER email customer care ' BROTHER PRINTER email customer care care ' BROTHER PRINTER email customer care care download ' BROTHER PRINTER email customer care care software ' free BROTHER PRINTER email customer care care . BROTHER PRINTER email customer care change, BROTHER PRINTER email hacked customer care changed, BROTHER PRINTER email hacked can't change customer care, change BROTHER PRINTER email customer care on iphone, change BROTHER PRINTER email customer care on ipad, change BROTHER PRINTER email customer care on android, BROTHER PRINTER email account hacked can't change customer care, how to change BROTHER PRINTER email customer care on droid, BROTHER PRINTER email customer care problems, BROTHER PRINTER email customer care not working, BROTHER PRINTER email account customer care rBROTHER PRINTER.
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
