How to remove the cover for Black & Decker, 750W Power Inverter
SOURCE: I purchased a black and decker 100 watt power..cant register it!!
http://www.blackanddecker.com/MemberCenter/ is the new site. Enjoy!
SOURCE: Is this inverter powerful enough?
You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
SOURCE: how do I replace the fuses in a 750 watt black and
look for a cover to maybe flip up or slide (most inverters fuses are coverd)
SOURCE: How do i tell when the inverter is charged?
Question does not seem to match this inverters capability.
INFO:
This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
Hope this tip was of some use.
R/
David
SOURCE: Black & Decker P1400AB fuse change
If it is the fuse inside the cigarette lighter plug, just unscrew it and put a new fuse in.
If you mean replacing the two 25amp fuses inside the inverter housing, you can bypass the fuses by soldering the two sides together. Or, if you want to put new fuses in, heat the solder holding the fuses in until they pop out and insert new ones.
As for opening the housing, good luck!! I ended up using steel cutters to rip off the plastic. The best option would be to buy a new one and return the old one in the package.
