Question about Karcher G 2600 VH Gas Pressure Washer
How to change oil Karcher (Robin engine) 2600 PSI Gas pressure washer
2 Related Answers
Thomas F. Schneider
  • 2715 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
Anonymous
  • 174 Answers
SOURCE: OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
Posted on Sep 20, 2009
No pressure...new pump
Gun could be the problem if you hear the engine pick up speed and you can feel the pressure on the hose.if engine speed doesn't increase than there is a governor issue with the engine.
Oct 03, 2014 | Karcher G 2600 VH 2,600 PSI Gas Pressure...
How do I fix a Karcher 2600 PSI pressure washer has water in oil..
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Aug 09, 2014 | Karcher G 2600 VH Gas Pressure Washer
Milky engine oil
suspect water in oil... just change the oil and see if it returns. it's very rare that a pressure pump can get water into the engine
Nov 12, 2013 | Karcher G 2600 VH Gas Pressure Washer
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
What viscosity oil is recomended for oil change?
  • Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
May 24, 2010 | Karcher G 2600 VH Gas Pressure Washer
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Sep 20, 2009 | Karcher Garden
Need to know what type of oil is to be used in a pump assembly for a karcher G 2600 ph
Hello:
10W30 oil but make sure it is NON DETERGENT. Also be sure the reservoir is only 1/3 to 1/2 full
Jun 30, 2009 | Karcher 2500 PSI Pressure Washer
Do I need to add oil to the gas for a Troy-Bilt 2500 power washer
This engine is 4-cycle. It does not require oil in the gas. Is the crankcase full of oil? Do you know how to check it?
May 05, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2600 psi pressure washer wont stay running
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher G 2600 VH Gas Pressure Washer Logo
359 people viewed this question
Top Karcher Garden Experts
Bruce Robin
Tim Venetis
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
