Question about Toshiba e-Studio 232 Black and White Copier
Error codes and their meaning for Toshiba e-studio 181 copier
Error code C44
Vikas Choudhari
    New Friend:
Toshiba e studio 181 copier problem when start come on screen err?
what is problem
Posted on Aug 23, 2016
Stone Corner
    New Friend:
Thanks a lot. Where can I buy a new fuse for the toner cartridge.
Posted on Sep 06, 2013
Chrysanthus Michael
    New Friend:
Toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Posted on May 13, 2013
5 Related Answers
Anonymous
  • 30 Answers
SOURCE: My e-studio 163 copier indicate code error c44 and
Hi how are you this is jack ([email protected])
your copier show error c44..
Dear you press 0 and 8 key simantenasly and On copier other hand.. copier panal show ..AJ.... after 1min AJ constand.. then you press 400 and Start key.. your copier show one value 5.or.6 or.7..every x.y.z ok.. Then you press 0 key and press intrept key.
COPIER REVERSE AJ MODE THEN OFF COPIER..
AND simple ON Copier.
DEAR PLEASE VOTE ME.
Thanks ,
Best Regards,
Posted on Aug 14, 2010
Testimonial: "it was perfect and many thanks"
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: My Toshiba e studio 167 is showing a c44 error
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Posted on Jun 30, 2009
Anonymous
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
Everett Lin
  • 990 Answers
SOURCE: what is error code f105 for an toshiba e-studio 520 copier?
Dear sir; There have your solution, try to turn power off and on, if can not reset , you have to replace HARD DRIVE, f105 is hard drive problem. good luck! if you need more help please let me know, HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
Anonymous
  • 66 Answers
SOURCE: error c44 call for service
C44-Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range.
You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Posted on Oct 04, 2010
Toshiba copier
for e207 model, error code should be in C44, F14, and etc...
Assume your error is C43, check the fuser thermistor, clear the error using 08-400 = Any value => "0"
Oct 01, 2015 | Toshiba e-Studio 207 Copier
Toshiba e studio 18 error c43 how to reset
Dear sir i have to problem in Toshiba estudio 18 error c44
and fuser unit check ok but please tell as error reset
Jan 05, 2014 | Office Equipment & Supplies
Error c44 studio
codes c43, c44, c45
problem with the fuser
thermistor review
thermal fuse
check connectors
Dec 05, 2013 | Toshiba e-Studio 35 Copier
Toshiba estudio 181 gives error code c44 any button not working
C44 indicates fuser problem.
Try perform 08-400, set to "0" to reset the error.
If persist, u need to check the themistor & heater lamp on the fuser unit.
Oct 02, 2012 | Toshiba e-STUDIO181
How removed toner indication still toshiba copier e-studio-181?
toshiba e-studio 181 toner indication patmanent still.
Feb 26, 2012 | Office Equipment & Supplies
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
I have a Toshiba studio 45 with error code c44, what can I do ?
You should apply to service Toshiba.
The Possible faults in lamp of the heating, thermistor, contact of the elements of fuzer or in signal of the controller of the direct current.
C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem
Oct 07, 2009 | Office Equipment & Supplies
My Toshiba e studio 167 is showing a c44 error code. What should I do?
Jun 30, 2009 | Toshiba E-Studio167 Copier
Toshiba 160 error code
c44 = fuser error
turn copier off
then 0 and set
Mar 31, 2008 | Toshiba e-Studio163 Copier
Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Toshiba e-Studio 232 Black and White Copier Logo
1,829 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
