Following a power outage, refrigerator goes on an off intermittently every few minutes, including interior lights and cooling. No longer cooling effectively.
To be short, the only thing in the machine that really has the capability of causing that is the compressor. Its got a floating short in and when it makes contact it trips the outlet/breaker. Check for any exposed wires just to be sure but I'm pretty certain that the compressor is the culprit and either it or the machine needs to be replaced or a proffesional sercvice tech called.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Refrigerator light goes out
look like door switch
HTML clipboard
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
SOURCE: Samsung refrigerator stopped working after a power outage. Only the lights comes on
needs to replace its relay
SOURCE: GE refrigerator not cooling after power outage
It sounds like the main control board is bad . After looking up the board , it is on a recall lisr by GE . You should call GE and have them come and check it .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Testimonial: "Thanks for finding this info. The tech came and found that the compressor had failed. It was still good to have your info in the back pocket. Thanx!"
SOURCE: Hotpoint s/s refrigerator hss25gfpjww not cooling ...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsh
