Question about Paragon 8145-20 Defrost Timer
SOURCE: I have installed 3 paragon
You need someone to come in and trace the wiring if you cannot figure it out. You said you had the Paragon wiring diagram already, if not the link below can be used.
http://www.uni-line.com/images/docs/refrigeration-8140series-wiring.jpg
This defrost time can be used for both hot gas and electric heater defrosting so check to see which defrost type is being used.
Posted on Nov 13, 2010
SOURCE: CAN YOU SHOW ME PARAGON TIMER 8045-21 THE WIRING
HI, I RECENTLY SAW A LISTING ON EBAY FOR THIS ITEM. THE PHOTO SHOWS THE WIRING DIAGRAM.
HERE'S THE LINK.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=110619214541&ssPageName=STRK:MESE:IT#ht_843wt_1139
Posted on Dec 02, 2010
SOURCE: I need a wiring diagram
Paragon 8145-20 is a 240VAC (2 phase) timer. I doubt you will be able to find a 3 phase type timer.
I would suggest you use this timer as a control and purchase either contactors or relays rated to handle the 3 phase load.
Posted on Dec 26, 2010
Nov 11, 2012 | Paragon 8145-20 Defrost Timer
Aug 21, 2011 | Paragon 8145-20 Defrost Timer
May 20, 2011 | Paragon 8145-20 Defrost Timer
Feb 11, 2011 | Paragon 8145-20 Defrost Timer
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
Dec 15, 2010 | Refrigerators
Dec 09, 2010 | Paragon 8145-20 Defrost Timer
Oct 11, 2010 | Paragon 8145-20 Defrost Timer
Aug 18, 2010 | Paragon 8145-20 Defrost Timer
Feb 05, 2010 | Paragon 8145-20 Defrost Timer
May 01, 2016 | Paragon 8145-20 Defrost Timer
560 people viewed this question
