My htc aria is now only playing music to the left ear of my heaphones, i have tried countless headphones and it is not the headphone but the htc aria itself that is broken. I think my audio jack is broken?
Check that you don't have pocket lint etc stuck inside the audio socket. Turn off the phone and use a paper clip to see if you can hook anything out. If you can't push the plug all the way in, it can cause the problem you describe. Otherwise take a look at http://www.urheadphones.net/ReplaceEarBuds
SOURCE: headphone symbol though no headphones in so cant talk to people
It sounds like your device may be paired with a Bluetooth headset. Try turning off bluetooth connectivity and see if that fixes the issue.
SOURCE: My HTC aria for what
Try to open the youtube in the browser(m.youtube.com) instead of app, becaue HTC aria processor doesnt support the FLASH.
SOURCE: When I unplug my headphones my HTC thinks they are
there is a problem with the headphone jack, there is a super small switch that tells the phone if something is plugged in or not, it is stuck thinking there is something, putting the jack in and out repeatedly can make it work again, if not you can contact htc and they will repair because it should be covered.
Testimonial: "Thanks for your help. Good suggestion. I will contact HTC next."
SOURCE: I have an HTC S523
Hi, you will have to disable the text messages tone to stop the call interference..
go to Setting/Sound&Notifications
go to notifications tab
select Event= New Text Message
set Play sound... and select ring tone of your choice...
For Custom ring tones ... you have to put the ring tone in Windows Folder
