Kohler Command Pro OHV Horizontal Engine with Electric Start 25 HP, Logo
A
Anonymous Posted on Apr 27, 2012
Cv25s engine backfire
Replaced bad ignition module now the engine backfires except at full throttle
2 Related Answers
Anonymous
  • Posted on Mar 11, 2011
SOURCE: kohler command 18 backfires when warmed up
kohler pro 18 on craftsman riding mower. Idles fine but lacks power at high speed. i installed a new carb. does not seem like it is not opening up full throttle and will back fire if i accelerate the throttle too fast.
Anonymous
  • Posted on Jun 11, 2011
SOURCE: Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
If a full a rpm cost backfire
If what you are saying is that when you reach maximum rpm the car backfires, first be aware that most ignition modules have two sections--one for low rpm and one for high rpm. Could be bad ignition module. Also possible that some tune up item (plug wires, dist. cap) is bad, or that the engine is running too lean at high rpms (bad fuel pump, dirty filter, etc.)
Fix cracking & popping in engines backfires in exhaust
This could be anything from bad ignition to timing to bad fuel supply (lean) to bad valves in engine. Run compression test to eliminate worst case, check both ignition and cam timing, vacuum leaks, ignition module.
3answers
1993 chevy corsica backfires
I think you have a valve problem. Need to remove valve covers and look for loose or broken rocker arms. If an exhaust valve does not open because the rocker is broken the trapped combustion gasses will revert through the intake when the intake valve opens. This can interupt the intake flow to other cylinders and prevent starting.
1helpful
1992 Lumina Backfire - I have a 1992 Lumina Euro, 77K miles, 3.1 V-6. Under moderate to hard acceleration the engine will backfire and you can smell gas. The spark control module, coils, wires, plugs,...
I know you mentioned the EGR valve has been replaced, but you may have a bad 'new' part. I know the car is electronic, but has anyone checked its ignition timing (timing belt been looked at, I know it only has 77k on it). Is the fuel pressure regulator OK and it vacumm supply?
Have replaced fuel pump, relay & fuel filter.
have you checked to see if you have a bad came or lifter. that would make it backfire. if it kind of spits fuel it maybe cam. if it throws fire than it could be timing like a bad chain.
4helpful
3answers
2helpful
3answers
Desiphering diag. codes for my 2006 harley davidson fxdi
intake leak or exhaust leak depending; most likely intake 95%
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
