Question about Rio Carbon MP3 Player
Rio carbon wont load any music?
Rio was working fine when i gave it away, person using it messed it up, was using windows media player to load music, but person I gave it to took it all off somehow they dont know how they did it, and now it wont reload music, and everytime i try the rio says no tracks.
Posted by Julia Whetstone on
Anthony White
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Try reformatting it then putting music back on it see how that helps
Posted on Nov 29, 2013
5 Related Answers
Anonymous
  • 277 Answers
SOURCE: rio pearl directory corrupted
first, and this is always good: If available, firmware for the Rio Carbon can be downloaded online. Second, this might be the problem: The Rio Carbon communicates with your computer differently in MTP mode than it does in MSC mode. When in MTP mode, the Rio Carbon cannot display hidden files in folders, cannot allow transfers to the root Rio Carbon directory, and cannot allow the creation of new folders. (Folders can be transferred to the Rio Carbon using drag-and-drop and copy-and-paste methods.) To use traditional folder options, change the Transfer Mode settings to put the Rio Carbon in MSC mode. Last, "..Removing the Rio Carbon from a USB connection before Idle is displayed on the screen may result in a corrupting the player's file system. If for any reason you suspect that your Rio player's file system has been corrupted, reformatting the player will restore the file system to its original state..."
Posted on Nov 28, 2005
Anonymous
  • 277 Answers
SOURCE: Rio Carbon 5gb pearl transfer problem
hi first of all update uour firmware: http://www.replaytv.com/support/rio/product.asp?model=267&SKU=90260554 also go to Software tab and update your Music Manager i belive this will solve all your problems good luck
Posted on May 08, 2006
mstr2kx
Mohammad Abumuailek
  • 102 Answers
SOURCE: rio s10
? Verify that the USB cable is securely inserted into the USB port on both the Rio Carbon and your computer. ? Connect the USB cable to a USB port on the back of your computer rather than to a USB port on the front of your computer. ? If using a USB hub, connect to a powered USB hub. Unpowered USB hubs may not work. ? Remove USB extension cables from the connection path. ? Disconnect other USB devices. ? Both Windows XP Service Pack 1 (SP1) (or greater) and Windows Media Player 10 (WMP10) must be installed for your computer to detect a Rio Carbon set in MTP mode. ? If you do not want to install SP1 (or greater) and WMP10 on your computer you should disconnect the Rio Carbon and change the Transfer Mode setting to MSC mode. Good Luck
Posted on Jun 25, 2007
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: How to take music off Rio Carbon
I have bad news - I was completely unsuccessful in dragging tracks from the rio to my computer. You can load songs, but you can't "unload" them with the Rio Carbon.
Just in case your computer has capabilities that mine does not, try this:
Double-click "My Computer" on your PC desktop
Double click the Rio Carbon icon
Double click the "Music" folder
Try dragging a single music file from the "Music" folder window to your PC desktop - it will either work, or it will say that it cannot copy the file to the specified location.
Posted on Apr 16, 2008
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
SOURCE: When I transfer music from Rio Music manager to my
Try to transfer the tracks from the explorer.
1 Connect the Rio Carbon to a computer using the supplied USB cable.
2 Double-click My Computer on the Windows Desktop or in the Start Menu.
3 Locate MP3 or WMA audio files on the computer.
4 Highlight files and/or folders to transfer to the Rio Carbon.
5 Click Edit.
6 Click Copy.
7 Double-click My Computer on the Windows Desktop or in the Start Menu to open another window.
8 In the new window, locate the Rio Carbon (X:) icon that is associated with the Rio Carbon. (X equals the drive
letter assigned to the Rio Carbon.)
9 Double-click Rio Carbon (X:).
10Click Edit.
11Click Paste.
Posted on May 25, 2010
When I transfer music from Rio Music manager to my Rio Carbon the music manager indicates transfer successful but the MP3 player states no tracks present?
5 Click Edit.
6 Click Copy.
10Click Edit.
11Click Paste.
May 24, 2010 | Rio Carbon MP3 Player
Filels won't delete
Try re-formatting your Rio
On windows just right click on it and click format.
This will remove any tricky tracks that just don't want to go away...
Mowcius
May 26, 2009 | Rio Carbon MP3 Player
How do i download/transfer my rio carbo mp3 music database to my ipod itunes music manager??
The Rio Carbon is completely incompatible with iTunes (which uses AAC format). It only accepts mp3, wma, and some WAV's. The Rio Carbon is still the best mp3 player I ever owned, but since Rio doesn't make them anymore, it will never be compatible with iTunes. You can use it with Rhapsody's Mp3 Only service, or any music service that gives you the files in mp3 format - but you can't sync the songs through the music service's "synchronize function" - you have to download the files to a location on your computer, and then use the Rio music Manager to transfer the songs to your device.
-Tha Mp3 Doctor
Mar 04, 2009 | Rio Carbon MP3 Player
Rio carbon
You must use the native software - still available on rio's website. No other transfer method will work with this player.
May 20, 2008 | Rio Carbon MP3 Player
Apr 13, 2008 | Rio Carbon MP3 Player
I presume you are using windows...
Go into start,
Then My Computer,
Your Rio carbon should show up as a removable device, double click on it,
Then you should have 2 or more folders: Music and recordings,
double click on music and all of your music will be in there,
you can then just copy and paste it to your documents or other folders as a backup.
Hope this helps
Mowcius
Tranfer from player to computer?
Go to Main Menu -> Settings -> Advanced -> Transfer Mode and select MSC. Worked for me.
Nov 18, 2007 | Rio CE2100 MP3 Player
Rio s10
May 24, 2007 | Rio S10 MP3 Player
Rio Carbon 5 g
When Microsoft initiated the DRM system, any Rio Carbon that was hooked into Windows Media Player had the previously working files invalidated. Happened to me as well. The player lasted me three years, and that is about as long as any Mp3 player is going to last we are finding out b/c of all the software snafus.
Jan 09, 2007 | Rio Carbon MP3 Player
Rio pearl directory corrupted
Nov 27, 2005 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
Top Rio Audio Players & Recorders Experts
Artur Heise
Jean Sintulaire
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
