Cameras Logo
Posted on Apr 27, 2012
How i change size from MB to KB - Cameras
julievelor
Level 1:
Habit-Forming:
New Friend:
  • Contributor 23 Answers
  • Posted on Apr 27, 2012
julievelor
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
23
Questions
5
Helped
3229
Points
80
There are 1000KB in 1MB, so multiply the number of MB by 1000 to get the number of KB.
I dont have mother board driver for system model awrdacpi
The Intel® Desktop Board D915GAG supports one Intel processor in an LGA775 socket. See the table below for a complete list of supported processors.
Processors not specifically listed by type and rated speed can have requirements that are not supported by the design of the desktop board. Use of unsupported processors can result in improper operation, damage to the desktop board or processor, or reduced product life.
Processor Family System Bus Frequency L2 Cache Size BIOS Version Intel® Pentium® 4 800 MHz 2 MB 0391 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0477 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0475 or greater
533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater
DOWNLOAD LINK IS GIVEN BELOW...........
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22Intel+Desktop+Board+D915GAG%22
1helpful
4answers
WINDOWS WILL NOT RECOGNIZE MY 640 GB ONLY 600 GB
If you bought a 640 GB hard drive when the drive is formatted it will be slightly smaller then the size listed on the box.
This is caused by a difference between the size of a GB as defined by windows versus the maker of the drive. The drive manufacture assumes that 1 GB is 1000 MB, where as windows assumes it is 1024 MB.
If you carry these assumptions all the way down to the byte level you get:
640GB = 640000 MB = 6.4 * 10^8 KB = 6.4 * 10^11 bytes
this is the base storage size of the drive.
Then windows takes this number and does the same in reverse to get the number of GB is displays:
6.4 *10^11 bytes = 6.25 * 10^8 KB = 610351 MB = 596.1 GB
There is nothing wrong with the drive, it's just a different unit of measurement.
4helpful
I need mercury 865 motherboard sound driver for windows 7
Drivers Version Specification Size Note Download
A3.69 Audio Driver_Realtek 23.7 MB
dl_bu_dl.gif V3.6 LAN Driver VIA 823X 4.07 MB
dl_bu_dl.gif V1.0 VGA Driver 14.1 MB
dl_bu_dl.gif V4.55 VIA IDE DRIVER 1.41 MB
dl_bu_dl.gif V4.12 VIA SATA RAID Driver 6.93 MB
dl_bu_dl.gif V1.0 VIA USB Driver 3.03 MB
BIOS Version Specification Size Note Download
V1.0 050818S-BIOS 510 KB
Manuals Version Specification Size Note Download
V1.0 User Manual 356 KB
8helpful
2answers
I have samsung C3510 Genoa. this cell phone is not supporting jar file exceeding size of 500 kb. please give solution...
Enter this code in standby mode: *#52828378#
You will see "JAVA Test Menu" screen. Select option # 6 which is "OTA Test". Here you can see "Maximum JAR size (KB) which is 400 KB by default. Just enter your own value like 2048 KB. Press "Save" and exit from it. Now you can install JAR file of upto 2 MB size. Keep in mind that your new setting (2MB) will change back to default value (400 KB) if you RESTART your mobile. So, this is just a temporary setting but works perfectly to install large JAR files.
212helpful
15answers
I have samsung champ gt-c3303 .It cannot run any java supported file what can i do for it ?
Just place a jar files(games or apps) on a memory card. Then just click on the apps or games it will install. Samsung champ will only install below 500 kb/apps or game, if you want to install higher than that just used this code by dialing *#52828378# you will go to Java Test Menu, then go to OTA test, change 500 to 4000 then save. You can now install as much higher than 500 kb but less than 4 mb.
Oct 05, 2010 • Cell Phones
IN NOKIA 6303i , IT OCCUPIES 4 KB FOR EACH MSG. CAN YOU HELP ME OUT WITH A SOLN,
That is the perfect size, there's nothing wrong with it. It's just a small size, i hope you know that 1024 kb = 1 mb. Good luck. Thanks for using FixYa.
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Digital pictures size
SHQ 2288 x 1712, jpeg, approx. 3.1 MB HQ 2288 x 1712, jpeg, approx. 990 Kb SQ2 1600 x 1200, jpeg, approx. 450 Kb SQ2 640 x 480, jpeg, approx. 77.8 Kb HQ movie 320 x 240, approx. 12.5 MB (20 second movie) SQ movie 320 x 240 , approx. 12.5 MB (41 second movie).
Record mode
2288 x 1712 SHQ, JPEG - approximately 1960 Kb 2288 x 1712 HQ, JPEG - approximately 762 Kb 1600 x 1200 SQ2, JPEG - approximately 465 Kb 640 x 480 SQ2, JPEG - approximately 72 Kb 320 x 240 HQ Movie - approximately 12.5 Mb (20 Second Movie) 320 x 240 SQ Movie - approximately 12.5 Mb (41 Second movie)
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
