Screw stripped cant change blade
This can be a real pain in the rear to deal with...are you sure you want all the drama?...find a way to bind the blade so that it won't rotate at all.....now get a pair of vice grips on that nut and try to loosen it......if the threads itself on the threads are stripped as you described, then you'll have to drill out the screw....meaning you'll have to find dead center and mark it with a heavy duty punch, then use a cobalt drill....1/8th inch to start with, then get a slightly larger bit.....at some point you should be able to chisel the head off the bolt and remove the blade.....now you'll have to easy-out the stripped screw from there......once the stripped screw is out....you'll have to determine whether there is enuf material left to drill and tap to a larger diameter bolt/screw.OPTION 2..you may be able to get a puller from the auto parts store.....but you could ruin the threads even worse than the condition they're in now.OPTION 3....get a good grip on the bolt head with vice grips, then get a buddy to tap a cold chisel horizontally between the bolt head and the blade, tapping easy while you pull up counter clockwise on the vise grips and see if the bolt screw head starts to back out at all.....if you may no progressOPTION 4.....if you have the room to do it...hacksaw the head of the bolt off, remove blade, now try to remove the screw with an easy-outand drilling good luck with this one.
please post back what you tried and results
SOURCE: I cannot seem to be
With the blade on and tight, block the blade with a piece of wood or someother means of securing it so it will not turn when you try to remove the nut. I then use a fifteen inch breaker bar and "massage" the bar with a four pound sledge hammer. A few moderate taps and it starts to loosen.
I hope this helps you get it off.
