SOURCE: Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
