Question about 3Com SuperStack Computers & Internet
HTTP/1.1 404 NOT FOUND! is coming while connecting the 3 com switch
I assigned the ip address for the 3 com switch 4 year back. Now i am trying the open the switch from browser it is giving 1.1.404 not found. But i am able to ping the switch ip address.
Posted by ramanaslv on
5 Related Answers
Anonymous
  • 78 Answers
SOURCE: EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router,  how it provides IP, and how access point is connected to it.
Posted on Oct 31, 2007
sramberg
  • 6 Answers
SOURCE: internet/ mms setting (PLEASE!!!!!!!!!)
Mine works fine- here are my settings on thePrada (multimedia settings for messages)
T-Mo MMS as connection
Proxy port is 9201
Proxy IP is 216.155.165.50
Internet mode is WAP
Profile name is T-Mo MMS
MMSC is http://216.155.174.84/servlets/mms
hope this helps
Posted on Dec 17, 2007
Anonymous
  • 4 Answers
SOURCE: Open Port 81 on Netgear Switch
Actually you need to open the port on the cable modem / router. Switches just pass the packets along.
Posted on May 22, 2008
Anonymous
  • 39 Answers
SOURCE: cannot connect 2nd computer
you can always give it a static ip...if you need to know how to do this repost here..
Posted on Jan 27, 2009
SteveRand
Steve Rand
  • 210 Answers
SOURCE: Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Posted on Feb 05, 2009
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
Tip
Change ip address
How To Change Your IP Address
How do I change my IP? There are MANY methods to change your IP. Some methods will work for you but may not work for someone else and vice versa.
If your IP is static, then you CAN’T change it without contacting your ISP.
If you have a long lease time (explained in this article) on your IP then you won’t be able to change your IP without cloning your MAC address, which I’ll explain later in this article.
It definitely helps if you know how the IP is being assigned to you.
You can read our DHCP definition to get a better understanding.
What is an IP lease time? IP lease time is the amount of time your ISP determines you’ll be assigned a particular IP. Some IP lease times are just a few days and other IP lease times could be set for a year or more. This setting is completely up to your ISP.
One of the easier methods to change your IP is to turn off your modem/router/computer overnight. Then turn it back on the following morning. This method WILL NOT work if your ISP has a long lease time set for your IP.
The following method will ONLY work if your computer is being assigned your external IP and not a router.
How to determine if your computer is being assigned the external IP
If your connection is direct to your computer and your computer gets the public IP and not a router, you can try this:
For Windows 2000, XP, and 2003
1. Click Start
2. Click Run
3. Type in cmd and hit ok (this opens a Command Prompt)
4. Type ipconfig /release and hit enter
5. Click Start, Control Panel, and open Network Connections
6. Find and Right click on the active Local Area Connection and choose Properties
7. Double-click on the Internet Protocol (TCP/IP)
8. Click on Use the following IP address
9. Enter a false IP like 123.123.123.123
10. Press Tab and the Subnet Mask section will populate with default numbers
11. Hit OK twice
12. Right click the active Local Area Connection again and choose Properties
13. Double-click on the Internet Protocol (TCP/IP)
14. Choose Obtain an IP address automatically
15. Hit OK twice
16. Go to What Is My IP to see if you have a new IP address
For Vista
1. Click Start
2. Click All Programs expand the Accessories menu
3. In the Accessories menu, Right Click Command Prompt and choose Run as administrator
5. Click Start, Control Panel, and open Network and Sharing Center. Depending on your view, you may have to click Network and Internet before you see the Network and Sharing Center icon
6. From the Tasks menu on the left, choose Manage Network Connections
7. Find and Right click on the active Local Area Connection and choose Properties (If you’re hit with a UAC prompt, choose Continue)
8. Double-click on Internet Protocol Version 4 (TCP/IPv4)
9. Click on Use the following IP address
10. Enter a false IP like 123.123.123.123
11. Press Tab and the Subnet Mask section will populate with default numbers
12. Hit OK twice
13. Right click the active Local Area Connection again and choose Properties
14. Double-click on Internet Protocol Version 4 (TCP/IPv4)
15. Choose Obtain an IP address automatically
16. Hit OK twice
17. Go to What Is My IP to see if you have a new IP address
Some people have inquired about manually assigning their IP address. This IS possible, but you run a very high risk of your ISP banning you from connecting to the internet. To manually change your IP, follow the steps above for your Operating System. In step 9 or 10, depending on your O/S, enter an IP similar to the one displayed in the command prompt window. For example, if the IP displayed in the command prompt window is 75.1.2.3, change yours to 75.1.2.4. You’ll also need to manually enter the Subnet, Gateway and DNS Server IP addresses as well. If the new IP you give your computer doesn’t work, chances are someone else on the ISP network has already been assigned that IP. You’ll need to move on to the next one and keep trying until you find an open one. However, some ISPs match up your MAC or modem data to the IP that’s been assigned. If those 2 things don’t match up, you won’t be able to connect no matter what. If your router gets the IP and not your computer, you’ll need to http in to your routers interface and manually assign the IP there. It’s pretty much the same method as assigning the IP to your computer. The method that varies is in how you reach your routers interface. You can get the instructions from your manufacturer’s website.
on Jul 02, 2010 | Computers & Internet
I want to connect my SCX 4500w to a new network (wireless). when i try to use a web page to configure the printer settings it doesn't response... I check the IP and write in in my Internet Explorer,...
You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
Mar 07, 2010 | Samsung SCX-4500 Laser Printer
What is the ip address for it's network/ethernet card?
The external ip address (the one assigned by your isp) can be found at: http://whatismyip.com/
The internal ip address (differentiates the computers on your network) can be found by running the command prompt (start --> run--> cmd or start--> all programs --> accessories --> command prompt) and then typing int eh following command: "ipconfig" (without quotes). It will be the set of numbers in the form 192.168.something.something
Good luck, let me know if you have any questions
Dec 28, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
How to configure dmz on linksys wireless n router?
  1. Log into your router. (If you need help how to do it let me know!)
  2. Go to th "Application & Gaming" tab.
  3. click on "DMZ"
  4. choose "Enable"
  5. Enter the IP address of the computer you want to put in the DMZ.
  6. Click "Save Settings"
Some notes:
  • Putting a computer in a DMZ is pretty risky, because all ports to this computer are opened. Make sure that all recent patches are applied and your virus software is up to date! A more secure solution is to use portforwarding. (See this site how to do that for a specific software for your router.)
  • Your computer should be set to a static IP. For two reasons:
  • A) DMZ will not work if your DHCP server (your router) assigns at one point a different IP address to your computer,
  • B) If a different computer gets the Ip address assigned that you specified in your DMZ settings, then that machine is exposed.
If you don't know how to assign a static IP address, let me know and I walk you through the steps.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | Port Designs Linksys Wireless-G Broadband...
Nortel NetDirect error on Vista
Hi kt_rutherfor, Firstly apologies for my late reply. I thought that this was going to be a firewall problem, but looking at your error again, I now dont think that. So I'm afraid that I dont know the answer to this, I do have an idea, after researching the problem that this is a Remote-NDIS host problem. Your Uni should be able to help you with this even if it isn't at there end.
Again sorry for not being able to help
Apr 07, 2009 | ASUS T3200 Notebook
Dynex 4 port Hub
Try to assign an IP address to the second computer like 192.168.0.101 Subnet 255.255.255.0 and Default gateway 192.168.0.1
Note: This one is an example of IP address, the IP address that you need to assign is in range to the router that you have or with in range to the modem.
Mar 08, 2009 | Computers & Internet
Oki3400n - how to assign a static ip address
I found this post via Google trying to solve the similar problem with C3200n.
>> this will then cause problems as all the pcs that are trying to print to this
>> printer will no longer be able to find the printer.
Originally, I also had this problem (with C200n, but it is probably similar). If I recall correctly, I solved it as follows:
1. Open the OKI LPR UTILITY from the machine you are trying to print from.
http://img8.imageshack.us/img8/4552/okilprutility2009080217.png
2. Choose Option > Setup
http://img8.imageshack.us/img8/9641/setup20090802171057.png
3. Make sure that the Auto Reconnect checkbox is checked.
Again, I believe that is what I did to solve that I couldn't print after power outages etc. The IP is not static, but it still solves the problem.
Static IP
Today I wanted a static IP for my OKI C3200n because sometimes there would be conflict between the IP for my printer and another machine in the house with a static IP.
What I did was the following.
1. In the printer menu locate the NETWORK MENU
http://img35.imageshack.us/img35/6889/dscn0525e.jpg
2. Go to the IP ADDRESS SET option, change from AUTO to MANUAL
http://img25.imageshack.us/img25/6122/dscn0526x.jpg
http://img195.imageshack.us/img195/7987/dscn0527j.jpg
3. Go to the IP ADDRESS OPTION, change to the desired ip address. In my case it was at 10.0.0.5, but I wanted 10.0.0.6 for the printer, so I changed it to that. Typically this is either 10.0.x.x or 192.168.x.x
http://img35.imageshack.us/img35/4407/dscn0528p.jpg
http://img90.imageshack.us/img90/1669/dscn0529r.jpg
4. Press the online button. The printer will reset the network connection (it took approx 1 minute)
http://img195.imageshack.us/img195/2539/dscn0530.jpg
5. This should be enough. You can try to ping the printer at the new IP, or navigate to the new IP in your browser:
http://img44.imageshack.us/img44/565/c3200nopera200908021755.png
Feb 01, 2009 | OKI C5400 Laser Printer
Belkin wireless router not assigning IPs for wireless clients
Some routers start handing out DHCP wireless IP's at 192.168.2.100. Try setting the upper limit at .110. If the router is found in a site survey (view wireless networks) but cannot connect, the limitation would be why.
Jan 10, 2009 | Belkin (F5D7230-4) Router (587009)
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Computers & Internet Logo
186 people viewed this question
Top 3Com Computers & Internet Experts
Mike
Sheldon Dedek
Vincent G
Vincent G
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
