Question about Jabra BT2050 Bluetooth Headset
How to get new batteries for jabra bt2050
I'm having trouble charging my Jabra BT2050 bluetooth. When I charge it, it blinks once only and won't go into charging mode. I've read that this indicates the problem with the rechargeable battery. So how do I get service to replace the battery. The product is still relatively new and in very good condition. Once I leave it charged for a while, i can hear it bleeping and it can be detected by my phone and can be paired with no problem. The problem is that soon after being paired, it lost the pairing - i guess because of "weak battery"...and doing that a few times before the battery went flat... Appreciate a practical advice please...! Cheers...
Posted by cybermaveric on
  • cybermaveric
    cybermaveric May 01, 2012
    There are no screw to be seen on the Jabra BT 2050 model center body...!
chenxue
    Scholar:
    New Friend:
  • 104 Answers
    • 1 Unscrew the small screw in the center of the Jabra's body.
    • 2 Slide the body to the left until it slips off.
    • 3 Unclip the existing, old battery.
    • 4 Clip the replacement battery into place.
    • 5 Replace the cover and the screw that held it down with the screwdriver.
    • You must charge the jabra headset's battery and go through an easy setup process before use.
Posted on Apr 29, 2012
1 Related Answer
Anonymous
  • 4 Answers
SOURCE: Jabra BT2050 blinks three times; doesnot pair up
Hold round center button for 10 seconds, light will stay on and be in pairing mode.
Posted on Dec 08, 2009
Yes, Could you please help me? I'm having problems with connecting my bluetooth.It tells me to add new device and i lost my instructions.
please specify your problem in more context words! what type of device are you trying to add? and what is the devices model number! FOR EXAMPLE : Jabra bt2050
Aug 28, 2010 | Jabra BT2050 Bluetooth Headset
Can't pair my VBT2050 with motorola Droid
BT2050 must be off.
Push power button and round top button on BT2050 ear piece at same time until white light stays on. Both must be held down together.
Once white light is continuosly on (not blinking) then put droid in "Scan for device " mode.
Pairing should then take place
Apr 05, 2010 | Jabra Bluetooth Headset with Adjustable...
How to get Jabra BT2050 in pairing mode? Problem - Rogers Tech Support asked me to ''wip'' my BlackBerry 8520, after that the bluetooth device stopped working and won't go into paring mdoe. Thanks.
Press and hold the center round on/off button for 10 seconds to put Jabra BT2050 into pairing mode. Type in pin "0000" when the BlackBerry 8520 detected the bluetooth headset, then the two should be paired. Hope this help.
Joseph
Jan 09, 2010 | Jabra BT2050 Bluetooth Headset
I bought a jabra bt 2050...i cant get the led light to stay on..it only wants to flash...and it wont pair with my blackberry storm
Try to press and hold the center on/off button for 10 seconds, this will put the Jabra BT2050 into paring mode.
Assumptions made:
1) The BlackBerry is Bluetooth enabled.
2) The Jabra BT2050 is fully charged.
Hope this help.
Joseph
Jan 05, 2010 | Jabra BT2050 Bluetooth Headset
My Jabra headset won't pair with my phone--my phone can't "discover" the headset. The headset is charged and when it is turned on, it blinks three times in a row
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Dec 14, 2009 | Jabra BT2050 Bluetooth Headset
Jabra BT2050 Bluetooth Headset not found on cell phone? I turned on the headset, and when i search for it, the headset doesn't show up. My phone just says "no new devices", and its not a known device
Try pairing it again. Make sure Bluetooth is enabled on phone, turn the BT2050 on by pressing and holding the side power button. Then, press and hold the center (round) button for at least 10 seconds (light will stay solid and it is now on pairing mode). Follow instructions on your phone. Hope this helps.
Nov 20, 2009 | Jabra BT2050 Bluetooth Headset
Jabra BT2050 Bluetooth Headset  Logo
255 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Robek Thirtysix
Robek Thirtysix
Level 1 Expert
Mosaub Al Masri
Mosaub Al Masri
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
