SOURCE: How do I use the tax button?
To change the current tax rate: Press the tax rate wanted (eg 5),then press "rate", then "tax+". The tax rate will now be set at 5%.
SOURCE: Settting up tax rate on Canon P1-DH III
push CA
hold TAX+ button until tax% starts flashing on the display
put in the required rate
push CA
should now be set
SOURCE: Setting tax rate on a canon P170-DH
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
SOURCE: Setting Tax rate
First, you have to make sure the calculator is set to two decimals. Then push the tax+ button, push the rate button. Now push the rate you want the tax ON, then push the rate button. If you want 2%, make sure to set the rate at 2, not at .02
SOURCE: TRYING TO SET THE TAX RATE ON MY CANON LS-120TS
just press tax till it blinks and then set the tax amount and then press tax button again
