Terk LeapFrog LF30S Logo
M Delp Posted on Apr 26, 2012
I have a Terk LF 30S and have it connected up but I am only getting the audio and not the video
1 Related Answer
Anonymous
  • 185 Answers
  • Posted on Jan 15, 2011
SOURCE: I have a Terk LF
Hello this is Dan Busa with DISH Network. I'm not quite sure if this is the answer you need, the way you need this set is you want the IR blaster pointing directly at the IR sensor on your receiver (the three holes by the power light) the actual extender just needs within close range of your remote.
Hooking up terk
Their should be a coax cable attached to the antenna that screws on to the threaded coax tuner input on the back of the TV... It will probably be the only threaded cable attachment point. If another tip on the cable look for the antenna in jack on the back of the TV. The rest will be HDMI or RCA inputs. After connecting the cable you will need to run the tuner setup scan on the TV from the setup function to scan for usable TV programs...
How to splice a sub-woofer to speakers
Normally the sub woofer is driven by a separate amplifier, unless the main speakers, such as in a pro audio setup have a special LF out set of terminals on the back of the speaker cabinet, in this case there is a hi powered low pass filter, fitted in side the speaker to route the LF energy to a sub woofer. Else you need a line lever LF signal spliter and a power amplifier to connect a sub woofer.
Hi christo here. My left front speaker is not working denon 1907 only 2 8ohm speakers conceded to port A. Tested speaker,all speakers working on test ecxept Lf Also tried B port Lf also not working
Too expensive to repair. Don't waste your $. Craigs List has hundreds of these for well under 100 bucks. Get one mfged in Japan not China. Circa 2007 and earlier.
I have a Terk LF 30S and have it connected to a Dish Network 311 and is transmitting to a Vizio LCD. I am having issues setting up the IR Extender ... I have no clue where to set it on the Sat Box.
Need to hook up to keenwood powered subwolfer 1050sw and im a girl and dont know how
The receiver has a subwoofer out jack on the back. The powered sub has a LF input jack on the back. Connect the two with an audio cable that has 'RCA' plugs on both ends.
My husband is looking for a user manual for a Terk s-video switch. He got the used item from someone at our church - but they had no documentation for it. Where can I get a user manual?
From my search results, the model number is Terk VS-4. You can view the user manual by clicking here. You need Adobe reader to view it.
More information is given below:
This unit allows you to feed up to 4 stereo audio and video sources to one unit (normally one television which has A/V inputs).
It also allows you to connect a second device such as a portable recorder or amplified loudspeakers to the front AUDIO only output (stereo minijack).
The two outputs are always live.
There are four switches on the top of the unit which allow you to select which of the four inputs you want to use.
Since this is a passive device (no AC or batteries) the input which you select is indicated by a red mark (non-illuminated) which appears when you select the input.
This unit is a perfect solution if you have a receiver or amplifier with no video switching or without enough video switching (or with no S-video capability).
...Placing the unit directly on top of a TV could cause electromagnetic interference. If this occurs simply move the cables and/or the switch box .
S-video signals will only be output when a corresponding S-video signal is connected to the input. For example, if you connect a standard VHS VCR to input 1 using composite video, only composite video (not S-video) will be output from Output #1.
Only output #1 should be used for dubbing or editing, since recording levels will drop if you use both Output #1 and Output #2 simultaneously."
Source
Antenna connection problem
if there is Radio Shack has them.
1helpful
Can't find the voltage specs for terk 9330 tower fm antenna
Product Specs: General: Product Type Radio antenna Recommended Use Indoor Width 3 in Depth 16.9 in Height 3.5 in Color Black Localization English Antenna: Wave Band AM, FM / FM: 87.5 - 108 MHz, 540 - 1700 kHz Impedance 75 Ohm Gain Level 42 dB Amplifier Built-in Included Accessories Connector coupler, impedance transformer Connections: Connector Type 1 x FM antenna ¦ 1 x AM antenna Power: Power Device Power adapter - external Manufacturer Warranty: Service & Support 1 year warranty Service & Support Details Limited warranty - 1 yearlet me know how this works out for u
Top Terk Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Terk Televison and Video Expert? Answer questions, earn points and help others
