Question about Tappan 30IN ELEC IGNa Oven
Oven door is open but the lock will not turn off
Posted by sherri roubis on
  • sherri roubis Apr 26, 2012
    the cleaning is not on and it is not hot anymore
    Dr is blinking in a little window and it is beeping
Oven door will not open
The lock motor (latch) has gone bad. Unfortunately, the part has been discontinued and is no longer available for this model.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Amana AOCS3040 Electric Single Oven
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
LED says "Locked" can't turn on stove. How do you unlock it?
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 16, 2009 | GE Profile JTP18 Electric Single Oven
Kenmore oven 41775790 locked door
after self cleaning with the racks still in oven, i cannot get the oven door open, locked down, does this have something to do with the racks left in oven during cleaning. what do i need to do
Jan 17, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
Tappan 30IN ELEC IGNa Oven Logo
Top Tappan Ovens Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Tappan Oven Expert? Answer questions, earn points and help others
