Question about RTO 50cc Moped Scooter
2002 roketa 50cc will not start
I have a roketa 50cc moped , im having trouble getting it started , i have checked everything from compression , spark , gas flow . the roketa turns over but wont start not even if i shoot starter fluid in the air box , i even tryed putting some in the the spark plug hole and nothing . i walk into the shop and started the roketa up on the 1st try one day , let it run for 20 mins and shut it off 2 hours later i tryed to start it again and NOTHING , i have tryed everything under the sun , im lost , im sure there is something im over looking can someone PLEASE help
Posted by bigdaddy1974 on
5 Related Answers
Anonymous
SOURCE: hi have a yiying 50cc moped and it keeps cutting out and its slow
take it for a full service, clean it, check your brakes r not to tight, check all your oil levels, clean your ait filter ( all done in ur service), check your bettery isnt flat, all that kind of **** n hopefully it will be a smooth runner again
Posted on May 07, 2010
fordexpert
  • 5692 Answers
SOURCE: Massey Ferg 24 won't start. Spark to plugs, firing
Lots to check for small engine. First, have Starter draw checked for spinning Voltage draw. May be turning below what is needed to get engine going. Check compression specs. 60 sounds better than 30, most engines should not be more than 10% different in cylinder to cylinder compression. Spray small amount of 30W oil in each cylinder to determine if compression changes. Rings at fault if it does help, valves at fault if it does not.
Did it fire with ether? Should have run for a couple of seconds with ether. The valve timing is important and you need to adjust the valves to insure best compression. Even if you have Specs to adjust a warm engine, you need to be close on a cold engine. Don't remember if Fergusons had optional adjustable lifters like Fords.
Bad coil? They can be bench checked. Check also with hot wire to coil disconnected if your switch is letting power go to coil in RUN position.
Check your Cam timing and distributor as well as the capacitor inside the Distributor. Firing order?
Posted on Jan 02, 2012
Anonymous
  • 12 Answers
SOURCE: 2007 50cc moped.wire with the fuse getting hot
Check the whole system over an see if evory thing is fastened securley,make shure that no two wires are toucing!
Posted on Oct 15, 2009
Anonymous
SOURCE: I have a problem with my 50cc moped/scooter.
set light to it
Posted on May 12, 2010
Anonymous
SOURCE: moped
the gapping is standard you can u a match book and if it slides between the gap easy it is fine if it wont goo in the gap it needs to be gapped more if there is alot of space between it, it needs to be closed up some.
Posted on Jun 28, 2010
Wiring diagrams MC-02-50b(MAUI-50ST)
http://www.chinesescooterreference.com/manuals_charts.htm
Jul 19, 2014 | Roketa 50cc Gas Moped Scooter
Got a kinroad 50cc scooter wont start got fuel got spark can anyone help?
SEE IF IT WILL START ON A FEW DROPS OF GAS, IF SO YOU NEED TO CHECK FUEL DELIVERY ,DRAIN OR CLEAN THE CARB MAY HAVE WATER IN IT OR IT MAY BE THE SOLENOID ON THE CARB THAT SHUTS THE FUEL OFF IT SHOULD CLICK WHEN YOU TURN THE KEY ON... JAY FL
Feb 02, 2012 | RTO 50cc Moped Scooter
My Peugeot vivacity 50cc moped won't start just
Hi, Check fuel tank that it has fuel. Check sparkplug and/or replace it. Make sure engine has spark when cranking it over. Good luck.
Sep 27, 2011 | 2010 Peugeot Vivacity Roland Garros
I have a 50cc 4 stroke chinese scooter. At the moment it will start and stop after a few seconds. Ihave checked for spark and fuel in carb all ok. The spark plug is not wet even after trying to start it as...
i have a 49.50cc beron motorscooter and when i received the scooter it had spark but now there is not any spark bought new sparkplug and new coil still no spark
Sep 17, 2010 | RTO 50cc Moped Scooter
Oct 15, 2009 | RTO 50cc Moped Scooter
RTO 50cc Moped Scooter Logo
175 people viewed this question
Top RTO Toys Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you a RTO Toy Expert? Answer questions, earn points and help others
