Question about Vizio 42 in. LCD TV
I broke my Vizio 42inch E422VA screen. Can I have it replaced?
Posted by mark troutwine on
  • Anonymous Mar 15, 2014
    vizio e422va wont turn on
Back2life Electronics
  • Vizio Master
  • 933 Answers
Yes but the cost to replace it will exceed the cost of a new set. I wish I would have come across your post earlier. I just sold a E422VA parts tv for $171 shipped with a mint LCD screen !!! your best bet would be to part it out. Either throw it on Ebay or try to sell it locally on Craigslist.
Posted on Apr 27, 2012
Coffee Tech
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Vizio Expert
  • 158 Answers
Highly recommend to buy a new TV because a new panel would cost more than a new TV. Just have your old tv used as for spare parts and use the profits from selling the old tv to contribute and buy a new one.
Posted on Aug 25, 2015
2 Related Answers
gopakumarg43
  • 76407 Answers
SOURCE: color lines on 42inch vizio
Hello
The y SUSTAIN board to your tV is faulty. It should be repalced.
Posted on Mar 01, 2012
Anonymous
  • 10 Answers
SOURCE: Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at [email protected] thanks, keith
Posted on Aug 10, 2009
My set was zapped by a nearby lightning strike. The screen still works. But it won't do anything past the "Vizio Internet Apps" screen. It then times it and shuts the screen off. It is a model #E422VA
Pull the plugs on everything - going to everything, starting with the TV and on out. Let everything just set for 20 min. Then, hook everything up to the TV BEFORE you plug in the TV. Turn it on. Good luck. . .
Apr 11, 2017 | Televison & Video
No HDMI signal on a Vizio E422VA
You mustfirsthave an HDMI cable attached. Check that.
Oct 25, 2016 | Vizio Televison & Video
How to fix a vizio 40" tv model E422VA dont turn on
Check the PS first since your set appears to be totally dead.
Nov 18, 2015 | Vizio E422VL 42 in. LCD HDTV
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
My Vizio E422va turns on but wont go past the start screen with the Vizio logo. The remote won't work either. It's like it freezes at start up.
Corrupted firmware. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 10, 2015 | Vizio E422VL 42 in. LCD HDTV
Hi I have e422va Vizio TV when I plug power coward only front light is turn white no led screen is black can you please help
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 15, 2015 | Vizio E422va 42-inch Lcd 1080p Hdtv With...
I have a Vizio E422VA that will get to the Vizio logo screen, hold for about 1 minute then power off with the power light blinking for about 2 minutes. I have replaced the main board, power supply boa
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 22, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
Vizio E422VA 42 in LCD television power light blinks
Hi I have Vizio e422va it's not turn on only front power light is on white when I plug power coward no led no screen is black please help
Mar 04, 2012 | Vizio GV42L 42 in. LCD Television
Color lines on 42inch vizio
Hello
Feb 29, 2012 | Vizio P42HD Television
Vizio 42 in. LCD TV Logo
467 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
