Question about Behringer Pro Mixer Djx750 Professional 5 Channel Dj Mixer With Advanced Digital Effects And Bpm Counter
HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Wire mixer to eq to amp
Posted by louie banton on
John McPherson
    Genius:
  • 1,212 Answers
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Posted on Apr 27, 2012
5 Related Answers
Fred Yearian
  • 5603 Answers
SOURCE: i need a wiring diagram for the main circuit board
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Posted on Aug 27, 2009
Fred Yearian
  • 5603 Answers
SOURCE: How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Posted on Dec 28, 2009
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
Fred Yearian
  • 5603 Answers
SOURCE: LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Posted on Apr 28, 2010
Fred Yearian
  • 5603 Answers
SOURCE: Where can I buy a fuse and fuse holder for my
DO NOT REPLACE A FUSE if it blows. You will do additional damage to the unit internally.
When these blow, there is damage inside that must be repaired before restoring power.
To get an exact replacement fuse holder it is best to get it from Behringer parts. This one has a switch in it depending on which way the fuse carrier is inserted.
Posted on May 12, 2010
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Oct 18, 2017 | Behringer Europower Pmp5000 Powered Mixer...
How to hook power amp to mixer
The output of mixer connects to channel A or B of the separate amplifier and the output of the am connects to the speakers. Amp channels are listed as A and B or 1 and 2 instead of Left and Right because the manufacturer does not assume how you may wire your system. Please remember that compression, limiters and EQ device connect between the mixer and the amplifier with their prespective IN and OUT levels adjusted accordingly.
Apr 30, 2012 | Mackie 1604 Vlz3 16 Channel Mixer
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
How do i hook up my Ultragraph Pro 6200 equalizer to my Europower PMP5000?
You use special "insert cables" to insert the EQ into the path from teh mixer to the power amps. Thee cables have three 1/4 inch jacks and are a Wye type cable that connect the TIP of the TRS jack to the TIP of the plug to be plugged into the OUTPUT of the EQ channel. A second cable ties teh RING of the insdert jack into the TIP of a plug that lugs in the INPUT of the EQ. You need two of these special cables for stereo operation.
Apr 30, 2011 | Behringer Fbq6200 Ultragraph Pro Equalizer...
How o u hook up behringer feedback destroyer to a powered mixer
In order for this to work properly it must be inserted between the last pre-amp stage and the power amp. Can you please update this with the mixer that you are using? With the make and model of the mixer, I can provide you with a connection description. Since each mixer will have different labeling and options, it is not possible for me to accurately describe the connections without hte make and model.
Thanks,
Dan
Feb 02, 2011 | Behringer Dsp1124p Feedback Destroyer Pro...
How to connect feedback destroyer pro dsp1124p ?
It all depends what you are connecting it to... Essentially wire it someplace between the preamps of microphones and the power amps that drive speakers. The only stipulation is that you want the levels to be "line level" signals.
If you are using a powered mixer, you will do this as an "insert" using the insert effect jacks. The preamp signal goes to the "in" of the destroyer, and the "out" goes to the following amp.
Dec 13, 2010 | Behringer Dsp1124p Feedback Destroyer Pro...
Wirings connections from mixer to equalizer to crossover to power amp to speaker
The connections can be accomplished in 2 ways: Direct or using insert cables. The most common way is directly as follows:
Mixer L/R ===> EQ Input L/R ==> Amp Input L/R ==> Speakers L/R
Using insert cables you would have a single 1/4" connector at the mixer end (inserted in to the "insert" L or R) and the other end into the EQ. If you need more details about this method, please post the model of the EQ so I can determine the type of insert cable required.
Hope this helps.
Dan
Mar 14, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Behringer Pro Mixer Djx750 Professional 5 Channel Dj Mixer With Advanced Digital Effects And Bpm Counter Logo
251 people viewed this question
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
