I brought a bizhub 420, how do i reset password
Posted by kerry on
Shaun Walker
    Scholar:
    New Friend:
  • 49 Answers
I had an older Minolta a couple of years ago. I'll try adapting what worked for it to this machine. Hopefully this will work.
Press the "utility" button. Then hit "admin settings". Enter a password of 12345678. Then hit "user authentication" and put in "off". Hit panel reset from the main menu.
Again, I'm not entirely sure this will work for the 420 but its worth a shot. Good luck!
Posted on Apr 26, 2012
Emmanuel
Hello how do i reset the administrative password of konica minolta bizhub 420?
Posted on Mar 02, 2014
sasoli
    New Friend:
How utilize admin
Posted on May 31, 2012
HOW WOULD I RESET ANY CODE IN MY BIZHUB 420
SOLUTION: To clear the message:
1. Enter Service Mode.
2. Select [System 1].
3. Select [Initialization].
4. Select [Counter Data].
5. Select [Fixing Counter].
6. Press the Start button.
7. Exit the Service Mode.
Oct 26, 2017 | In Office Equipment & Supplies
Have a tech come out admin password can change many things. should be done by a tech
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 30, 2014 | Konica Minolta bizhub C250 All-In-One...
Where do i find the serial number on the bizhub 420
print the meter count sheet
Dec 06, 2013 | Konica Minolta bizhub 420
C2702 on bizhub 420
Check the transfer and seperation assy. located on the right side door. has a plastic screen below the screen are two wires very thin might be broken shooting out the HV board and or main board remove the assy and replace the wires first
Nov 24, 2013 | Konica Minolta bizhub 420
How do i reset error C4701 of bizhub 360
4701=index sensor abnormality, turn off main switch turn back on.
Jan 21, 2013 | Konica Minolta bizhub 420
Reset password bizhub 211
how can i reset the password for my konica minolta bizhub 211 to remove the maintainance call 2 display?
Nov 21, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
Bizhub 420 error code c-2801
error code 2801 plesce relese the code prectical met
Feb 08, 2010 | Konica Minolta Office Equipment & Supplies
Konica Bizhub Password Reset
Konica Bizhub c350 default password is 12345678 give that a try
Mar 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Reset voicemail password
Just enter 0000 fron the phone.
Jan 14, 2009 | Mitel Superset 420 Corded Phone
836 people viewed this question
Marvin
Marvin
