SOURCE: Acer Extensa 503T
Oops. The above link to the Extensa 50x-510 Service Guide was incomplete. Here's the real link:
http://www.mmicro.it/cmp_img/esplosi/extensa/extensa500-50x-510.pdf
Note: you have to remove the CPU heat sink to get at the battery. Not sure you can just put it straight back on after replacing the battery or if you have to use a new heat sink pad? Looking into it.
SOURCE: Unable to locate CMOS battery on mainboard
Not sure on your model laptop. The battery is usually a 3volt lithium button battery approx the size of a small coin.
The battery could be located on the bottom of the laptop under one of the scewed panels to one side of the opening or it may be under the keyboard.
SOURCE: Hi, i want to reset a bios password on Acer
The bios is accessible by pressing F8 (IF Windows) after starting your computer.
SOURCE: where is located jumper clear cmos in acer extensa 5620z
Try here for info;; http://support.acer.com/acerpanam/manuals/acer/0000/userguides/EX_5620_5610_5220_5210_UG_EN.pdf If the info is not available here, you may have to remove the bios battery which may require disassembly of the notebook.. If this is required, my advice would be to take the notebook to your local repair shop. Disassembly of a notebook is complicated and time consuming and can be fraught with issues. Incorrect disassembly can damage the electronics and render the notebook useless.
SOURCE: password bios of extensa 4620z
You should be able to remove the password from the CMOS setting.
Just select F1 at boot up and locate the password section once you are in the CMOS Setting then clear it .
Regards
