Question about OKI C Office Equipment & Supplies
Oki 131 fatal error
On the display
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: oki c5200 "Fatal Error 106"
from your service manual....main board issue
Posted on Jan 16, 2008
Jeff Hughes
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
Anonymous
SOURCE: does anyone know what is
If you look on top of the fuser roller(upper orange roller), there is a thermistor (orange rectangle plastic that rides on the roller) you will see four wires going into that housing. Two are for the thermistor and the other two is for the fuse that is built into the housing. You would have to use a soldering iron to melt the plastic that the fuse is sitting in. You would have to figure out what to use as a fast blow fuse.
Okidata makes it difficult to take out the thermistor because the nut is locktite on the screw. Try using the soldering iron to melt it. Just make sure you dont damage the thermistor.
Posted on Jul 03, 2009
Anonymous
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
Jeff Hughes
  • 97 Answers
SOURCE: oki c9600 fatal error 175
Error 175
Fuser Thermistor
short-circuit or Open
is detected (High
Temperature (HOT)
or Low Temperature
(COLD))
Turn ON power again.
Leave in that state for 30
minutes then turn ON power
again.
Posted on Mar 29, 2010
OKI C830 Error code 131
This is an error for the yellow LED head. Check the connection. If you feel confident enough try moving the LED heads around. If the error moves with the LED head then it needs to be replaced. If the same error occurs the the CU pcb need to be replaced.
Apr 07, 2014 | Oki Electric Industry C830DN Led Printer
How do i fix error 131 on oki printer
Please confirm the model and error code. I have checked the technical manual for the B410d and there is no reference to error 131.
Apr 07, 2014 | Oki Electric Industry B410D Laser 30PPM...
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "[email protected]" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | OKI C5200n Laser Printer
How do i fix a 131 fatal error?
FATAL ERROR 131, 132, 133 OR 134 ON THE DISPLAY ON POWER-UP
CAUSE - ONE OF THE LED PRINT HEADS IS DISCONNECTED
SOLUTION - RECONNECT THE RIBBON CABLE TO THE PRINT HEAD
Just for information, the led print heads are the four assemblies that hang down from the lid of the machine when you open it.
Sometimes they become unclipped, and the ribbon cables can get pulled loose.
131 probably means the front one.
Mar 04, 2011 | Office Equipment & Supplies
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
Mar 19, 2009 | OKI C5400n Led Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
35 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
