Remote hardly ever worked - want to use yamaha surround sound remote as universal remote. what is the universal remote code for this product?
SOURCE: philips universal remote code for direct tv.
I have a code table for you, you may try this if its different than yours. Here is the direct link (You need Adobe Reader to open it)
Good Luck
SOURCE: universal remote codes
try this website it might be of help.
http://www.universal-remote.net/philipsmagnavox.html
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved (remember that at times a bit of
to and fro dialogue may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: Need help finding DVP3140 remote programming code for comcast universal remote
Since the codes that Comcast gave you did not work, there is a very high possibility that the remote control is not compatible with the DVD player. You cannot expect universal remote control to work with all devices, regardless of its make. Philips does not have codes for this DVD player because it is the maker of the universal remote control that sets the codes.
