Rebuilding a reel
SOURCE: penn fishing reels
For a Penn GTO 220, pls check this page an exploded view of the GTO220 that details parts and their placement. It is a PDF file and would need Abobe Acrobat Reader to view and print.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
SOURCE: I need assembly instructions so I can put my reel
have you rang the reel makers,they would send you a print out for a small fee or you can go online to www.mikesreel repairs.com i have printed off quite a few for my own use. hope this helps.regards barry.
SOURCE: ladyfish fishing pole by shakespeare
try switching sides of the handle by holding the bell and reeling then screw it in on the other side of the real by just reeling in. If that doesn't work then take all the line out and reel in some new line the opposite way.
SOURCE: I just took my father's
http://www.mikesreelrepair.com/schematics/thumbnails.php?album=9
Go to this website above it has schematics of many older reels.
Otherwise contact Pflueger, they will be only to happy to help you. Use the Contact link, and ask them for a schematic, if you cannot find one anywhere else.
www.pfluegerfishing.com/
