Washing Machines Logo
Anonymous Posted on Apr 26, 2012
Fisher & Paykel 6.5 turns on but doesn't start
Second hand. I Have done 4 washes so far but now it won't start. I can turn it on and select certain washing preferences but it won't start!
  • 2 more comments
  • Anonymous May 09, 2012
    When i push the start button it makes a sound but nothing happens
    I tried leaning it against the wall then spinning the fan. It spun really easily...
    Also, I have nothing inside it (neither water or clothes).
    I have tunred it off at the wall and after 20 min i'm gunna try bypassing the trip out switch... I'll keep you posted.
    ok I haven't tried the pypass yet but this is what i have done.
    1.With the machine off: Press and hold the WASH TEMP DOWN button and then the POWER button until the machine gives 2 short beeps and lights up.
    2. Press the SPIN SPEED UP button 3 times so that the HOLD and SLOW LEDs are illuminated.
    3. Look at the 8 LEDs accross the top that show the progress of the cycle. Tell me which ones are illuminated. List them for me please (example: 1st, 6th,7th) From LEFT to RIGHT
    I think I did it right. I tried twice.
    Nothing lights up at the top.
    All that is lit is high low (water level) and medium hold (speed)
    I only do cold wash because we only have a cold tap.
    I tried switching the tap into hot water to see if the cold water valve was broken. Still no action.
    Just opened the machine up. I see a white plastic lever looking thing on the top right. What is that meant to be connected to?
Greg Stephen
Level 2:
  • Fisher and P... Expert 566 Answers
  • Posted on Dec 26, 2013
Greg Stephen
Level 2:
Answers
566
Questions
Helped
224527
Points
688
That lever is the out of balance switch
Service manual link below, you need Adobe reader to biew PDF's
http://www.angelsnz.net/ZL3SV/misc/F&P%20Service%20manual%20517735.pdf
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 03, 2009
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Anonymous
  • 41 Answers
  • Posted on Jan 31, 2010
SOURCE: My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
Anonymous
  • 3 Answers
  • Posted on Feb 20, 2010
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Anonymous
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
luisa_sgro
  • 713 Answers
  • Posted on May 27, 2010
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Fisher and paykel MW511 series 11, phase 6, control panel lights up, beeps through all buttons, but start button beeps but doesn't start
there is a lid switch located under the top of the machine on the right hand side activated by a magnet in the lid this is probable faulty
Fisher & Paykel Intuitive IW709AU washing machine
this is a reset ok 1 open the door 2 put the program on the off position 3 turn the machine on 4 if you have a start button press it and hold it in for 2 mins then let go ,,,if you don't have a start button just go to follow the rest 5 put the power button on 6 shut the door it should do nothing then open the door put on you spin then shut the door wait till it finish ok job done hope this helped
3helpful
2answers
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Fisher Paykel Ecosmart WA37t26gw2 won't drain
Check your belts and replace if faulty
turn the pump by hand with belt off to see if pump is jammed
still no go, you may have a faulty electronics board.
Hi My mw512 fisher paykel washer won't Drain,how do i remove the drain pipe at bottom of tub? it won't seem to just pull off, des it need to be turned? cheers Michelle
I have a model 11, but I believe they are the same. The end at he outlet of the pump actually has tabs on it. Just twist and pull. Make sure the tabs are ligned up with the slots before you pull too hard.
2helpful
Water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
