Question about Hitachi P42H401 42 in. Plasma HDTV
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Problem with Hitachi P42H401 42 in. HDTV Plasma... I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volume completley down to 0. Picture is fine. Removed all components (dvd player, cable box ect) even just TV over the air. I have tried unplugging the TV for 30 minutes and it still happens.
Posted by Lew Morgante on
SD Tech
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Posted on Apr 26, 2012
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Posted on Dec 28, 2007
Anonymous
SOURCE: Hitachi P42H401 - No Picture or Sound. Some Menus work.
find and push the "reset button"
Posted on Sep 02, 2007
Anonymous
  • 225 Answers
SOURCE: Floating Horizontal Line
Sounds like a bad component on the video board. These days, TV techs just swap out boards for whole new ones.
Posted on Nov 17, 2008
Anonymous
SOURCE: 42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
Posted on Jun 03, 2009
Anonymous
SOURCE: My Hitachi comes on but no cable picture unless I
now do you have a cable box if you do disgard
if not tray to rescan for chanels and after the tvv is done scaning
hit menu
then
setup
then
rest software
then
no for resting the tv to the manufacter setting after going off
and that would take care of the problem
Posted on Aug 05, 2009
Y Component Cable Related - Internal Static Noise
It sounds like one of those cables has a defective ground. The static noise you are experiencing is cause by the cables not inside the TV. Try using different cables to isolate the problem and get new ones.
Good Luck.
Feb 17, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Have an Hitachi 42 PMA400e Plasma Tv.
Unfortunately, if there is no headphone connector on the TV there is no practical way of accomplishing the alternate arrangement.
Mar 21, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
I have my Hitachi 42HDT79 42 in. Plasma Television on my wall and I have no voice, just a loud squeeing noice. It doesn't matter what volume its on.
It of course may be a audio problem in the set (main board) but is a box or anything external being used for sound on the set? Same problem with a DVD etc the only thing connected to the set?
Jun 06, 2012 | Hitachi 42HDT79 42 in. Plasma Television
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Sound will go to loud static noise, but picture is fine
it sounds like you need someone to look at it for you so fix it under warrenty if you can. Maybe buy a set top box and source your sound from there. also buy 5.1 surround (if you like as its a excuse to upgrade) for your speakers.
Jun 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
HITACHI CMPAD14D 42 in plasma it has a black strip some 3 inches wide runing near the middle of the tv from top to bottom and it some time comes on then dissapears and so on and so forth
hITACHI CMPAD14D 42 nel plasma ha una striscia nera di circa 3 centimetri runing ampio vicino al centro della tv da cima a fondo e che da qualche tempo si accende poi scompare
Oct 02, 2008 | Televison & Video
Hitachi P42H401 42 in. Plasma HDTV Logo
700 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
